Master Node Flavor
Check Items
Check whether the flavor of the master nodes in the cluster is the same as the actual flavor of these nodes.
Solution
This issue is typically caused by modifications made to the master node. This upgrade may reset the node.
If you are unsure about the impact, submit a service ticket to contact O&M personnel.
