Node CPU Cores
Check Items
Verify that the master nodes in your cluster have more than 2 CPU cores.
Solution
The master nodes have only 2 CPU cores, which may lead to a cluster upgrade failure.
Contact technical support to expand the number of CPU cores to four or more.
