Help Center/
Cloud Container Engine/
User Guide (ME-Abu Dhabi Region)/
Clusters/
Upgrading a Cluster/
Troubleshooting for Pre-upgrade Check Exceptions/
Node CPU Usage
Node CPU Usage
Check Items
Check whether the node's CPU usage is above 90%.
Solution
- Upgrade the cluster during off-peak hours.
- Check whether too many pods are deployed on the node. If yes, reschedule pods to other idle nodes.
Parent topic: Troubleshooting for Pre-upgrade Check Exceptions
