SSH Connectivity of Master Nodes
Check Items
Check whether your master nodes can be accessed using SSH.
Solution
There is a low probability that the SSH connectivity check fails due to network fluctuations. Perform the pre-upgrade check again.
If the check still fails, submit a service ticket to contact technical support.
