Updated on 2025-11-24 GMT+08:00
How Do I Retain My Backups Permanently?
You can retain your backups permanently through manual or automatic backup (backup policies).
Manual Backups
You can permanently keep backups that you manually created as long as you do not delete them and your account balance is sufficient.
Automatic Backups
To keep automatically generated backups permanently, set Retention Rule to Permanent or set the retention period to 99999 days.
