- What's New
- Function Overview
- Product Bulletin
Billing
- Billing Overview
- Billing Modes
- Billed Items
- Billing Examples
- Billing Mode Changes
- Renewing Subscriptions
- Bills
- Arrears
- Billing Termination
- Cost Management
Billing FAQ
- How Is CBR Billed?
- What Is the Billing Cycle of Pay-per-Use Vaults?
- How Do I Disable CBR?
- How Do I Unsubscribe from CSBS or VBS Resource Packages?
- Why Is a Message Displayed Indicating Insufficient User Rights When I Create a Policy?
- What Can I do If a Yearly/Monthly-Billed Vault Is About to Expire?
- How Do I Unsubscribe from a Vault?
- What Should I Do If the Fee Is Too High When I Expand the Capacity of a Vault?
- Why Are CBR Backups Displayed on the VBS Console?
- How Do I Purchase a CBR Replication Traffic Package?
- What Resources Do I Need to Implement Cross-Region Backup Replication?
- Why AM I Still Being Billed After a Resource is Deleted?
- Getting Started
User Guide
- Management permissions
Vault Management
- Overview
- Viewing a Vault
- Deleting a Vault
- Associating Resources to a Vault
- Dissociating Resources from a Vault
- Migrating Resources from a Vault
- Expanding Vault Capacity
- Reducing Vault Capacity
- Changing from Pay-per-Use to Yearly/Monthly
- Changing Vault Specifications
- Replicating a Vault Across Regions
- Managing Vault Tags
- Managing the Enterprise Projects of Vaults
- Enabling Backup Locking
- Backup Management
- Policy Management
- Organizational Policy Management
- Application-Consistent Backup
- File Backup (Supported Conditionally)
Restoring Data
- Restoring from a Cloud Server Backup
- Creating an Image from a Cloud Server Backup
- Restoring from a Cloud Disk Backup
- Creating a Disk from a Cloud Disk Backup
- Creating a File System from an SFS Turbo Backup
- Restoring from a Desktop Backup
- Restoring from a File Backup
- Restoring from a Hybrid Cloud Backup
- (Optional) Migrating Resources from CSBS/VBS
- Managing Tasks
- Cloud Eye Monitoring
- Recording CBR Operations Using CTS
- Quotas
- Appendix
Hybrid Cloud Backup Feature Guide
- Hybrid Cloud Backup
- Application Scenarios
- Constraints and Limitations
VMware Backup
- VMware Backup Process
- Downloading and Installing eBackup
- Configuring eBackup
- Adding a VMware Protected Environment
- Preparing for VMware Backup Storage
- Performing VMware Backup
- Restoring Data Using VMware Backups
- Managing a Protected VMware Environment
- Managing VMware Backup Storage
- Managing VMware Backups
- Common Operations
Best Practices
Using a Custom Script to Implement Application-Consistent Backup
- Using a Custom Script to Implement Consistent Backup for MySQL
- Using a Custom Script to Implement Consistent Backup for SAP HANA
- Using a Custom Script to Implement Consistent Backup for Other Linux Applications
- Verifying the Application-Consistent Backup Result
- Protecting SQL Server
- Troubleshooting a Custom Script Error
- Performing Periodic Recovery Drills Using the Backup Data
- Creating Backup Policies Based on Service Tiering
API Reference
- Before You Start
- API Overview
- Calling APIs
CBR APIs
- Tasks
- Protection
- Backups
- Backup Sharing
Vaults
- Creating a Vault
- Querying a Specified Vault
- Querying the Vault List
- Modifying a Vault
- Deleting a Vault
- Applying a Policy to a Vault
- Removing a Policy from a Vault
- Querying the Vault List in Other Regions
- Batch Modifying Vaults
- Setting Auto Backup for a Vault
- Creating a Yearly/Monthly Vault
- Querying Vault Usage of a Project
- File Backup
- Tags
- Policies
- Organizational Policies
- Metering
- Operations
- Restore Points
- Projects
- Application Cases
- Appendix
- SDK Reference
Troubleshooting
- Failed to Execute a Backup Task
- Failed to Delete a Backup
- Failed to Expand the Vault Capacity
- Failed to Attach Disks
- Data Disks Are Not Displayed After a Windows Server Is Restored
- Failed to Cancel Backup Sharing
- Failed to Download or Install the Agent Required by Application-Consistent
- Failed to Install the Agent on Windows
- Failed to Implement Application-Consistent Backup
- A Server Created Using an Image Enters Maintenance Mode After Login
- Failed to Migrate VMware Backups to the Cloud
- Failed to Restore a VMware Backup to a Cloud Server
- An Error Message Is Displayed Indicating that the Path of a Storage Unit Is Invalid
- Failed to Import an eBackup Image Template, with an Error Displayed Indicating That the File Is Invalid
- The Download Dialog Box Disappears When I Download eBackup on a VMware VM
- File Backup Failed Due to Inconsistent Time Between Backup Client and UTC Time
- Concepts
Billing
- Can I Change a Server Backup Vault to a Disk Backup Vault or the Other Way Around?
- What Charges Will I Incur When Using a Backup to Create an Image?
Backup
- Do I Need to Stop the Server Before Performing a Backup?
- Can I Back Up a Server Deployed with Databases?
- How Can I Distinguish Automatic Backups From Manual Backups?
- Can I Choose to Back Up Only Some Partitions of a Disk?
- Does CBR Support Cross-Region Backup?
- How Do I Migrate Server Data Across Regions Using Server Backups?
- Can I Back Up Two Disks to One Target Disk?
- How Do I Replicate a Disk to the Same AZ in a Region as the Source Disk?
- Can I Migrate Backups Between Vaults?
- Can I Use Its Backup for Restoration After a Resource Is Deleted?
- How Many Backups Can I Create for a Resource?
- Can I Use an Incremental Backup to Restore Data After a Full Backup Is Deleted?
- Can I Stop an Ongoing Backup Task?
- How Do I Reduce the Vault Space Occupied by Backups?
- How Do I View the Size of Each Backup?
- How Do I View My Backup Data?
- How Long Will My Backups Be Kept?
- How Do I Implement Periodic Full Backups for My Resources?
- How Do I Query Resources that Have not Been Backed Up?
- Is There Any Requirement on the Network Bandwidth During Data Backup?
Capacity
- How Large of a Vault Do I Need?
- Why Is My Backup Size Larger Than My Disk Size?
- What Can I Do If the Vault Capacity Is Not Enough?
- Why Does the Used Capacity of a Vault Change Only Slightly After I Deleted Unwanted Backups?
- Will Backup Continue If the Usage of a Vault Reaches the Upper Limit?
- How Do I Adjust the Vault Capacity Alarm Threshold?
Restoration
- Do I Need to Stop the Server Before Restoring Data Using Backups?
- Can I Use a System Disk Backup to Recover an ECS?
- Do I Need to Stop the Server Before Restoring Data Using Disk Backups?
- Can a Server Be Restored Using Its Backups After It Is Changed?
- Can a Disk Be Restored Using Its Backups After Its Capacity Is Expanded?
- What Can I Do if the Password Becomes a Random One After I Use a Backup to Restore a Server or Use an Image to Create a Server?
- What Changes Will Be Made to the Original Backup When I Use the Backup to Restore a Server?
- How Do I Restore Data to a New Server?
- How Do I Restore a Data Disk Backup to a System Disk?
- Can I Use CBR to Restore Data to Any Point When the Data Was Backed Up?
- Can I Stop an Ongoing Restoration Task?
Policies
- How Do I Configure Automatic Backup for a Server or Disk?
- Why the New Retention Rule I Changed Is Not Applied?
- How Do I Back Up Multiple Resources at a Time?
- How Do I Retain My Backups Permanently?
- How Can I Cancel Auto Backup or Auto Replication?
- How Can I Have the System Automatically Delete Backups That I No Longer Need?
- Why Aren't My Backups Deleted Based on the Retention Rule?
- Optimization
- Is There a Quota for CBR Vaults?
- Can I Merge My Vaults?
- How Do I Delete a Backup That Has Been Used to Create an Image While Retaining the Image?
- Can I Export Disk Backup Data to Another Server?
- Why Do I Need a Vault to Accept the Image Shared to Me?
- Can I Download Backup Data to a Local PC?
- How Do I Copy Disk Data to Another Account?
- Videos
More Documents
- Getting Started
- Vault Management
- Backup Management
- Policy Management
- Restoring Data
- Managing Tasks
- Monitoring
- Quotas
- Concepts
- Billing
Backup
- Will the Server Performance Be Affected If I Delete Its Backups?
- Capacity
Restoration
Policies
- How Can I Cancel Auto Backup?
- Optimization
- Troubleshooting Cases
- Appendix
- API Reference (ME-Abu Dhabi Region)
Best Practices (ME-Abu Dhabi Region)
- Verifying the Application-Consistent Backup Result (Linux)
- Verifying the Application-Consistent Backup Result (Windows)
- Protecting SQL Server in Failover Cluster Mode
- Protecting SQL Server in Always on Availability Groups Mode
- Change History
User Guide (Paris)
- Getting Started
- Vault Management
- Backup Management
- Policy Management
- Restoring Data
- Managing Tasks
- Monitoring
- Auditing
- Quotas
- Concepts
Backup
- Capacity
Restoration
Policies
- Optimization
- Appendix
- API Reference (Paris)
Best Practices (Paris)
- Change History
- Getting Started
- Permissions Management
- Vault Management
- Backup Management
- Policy Management
- Restoring Data
- Managing Tasks
- Monitoring
- Quotas
- Concepts
Backup
Restoration
- Policies
- Others
- Appendix
- API Reference (Kuala Lumpur Region)
Best Practices (Kuala Lumpur Region)
- Change History
User Guide (Ankara Region)
- Getting Started
- Vault Management
- Backup Management
- Policy Management
- Restoring Data
- Managing Tasks
- Monitoring
- Quotas
- Concepts
Backup
- Capacity
Restoration
- Policies
- Others
- Appendix
- API Reference (Ankara Region)
Best Practices (Ankara Region)
- Change History
- Glossary
On this page
Show all
Help Center/
Cloud Backup and Recovery/
User Guide (ME-Abu Dhabi Region)/
FAQs/
Capacity/
Symptoms
- There is no difference or an increase in size between the original backup and a backup generated after a file is deleted.
- The ECS backup size is larger than the used disk space obtained from the file system.
Possible Causes
Possible causes are as follows:
- The backup mechanism itself causes this problem. The cloud server backups, SFS Turbo backups, and cloud disk backups created using CBR are all block-level backups. Different from file-level backups, block-level backups are performed by sector (512 bytes) each time.
- The metadata of the file systems on the disk occupies disk space.
- To reduce performance overhead, the file system adds a delete marker for the deleted file, but does not erase the data that has been written to the sector, and the metadata on the sector still exists. Block-level backups cannot detect whether data on a sector is deleted or not, but only determine whether a backup needs to be performed by checking whether all data blocks are zero blocks.
- CBR determines whether data in each sector changes by comparing two snapshots. Data changes include data addition, modification, and deletion. Backup is not performed if there are no data changes. If there are data changes, CBR further checks whether data blocks in the sector are all zero blocks. If so, backup is also not performed. Backups are performed only when there are non-zero blocks. If the data is deleted but metadata in the sector is not, the data block is also recognized as a non-zero block, and backups will be performed.
Parent topic: Capacity
