Updated on 2025-11-24 GMT+08:00
Expanding Vault Capacity
You can expand the size of a vault if its total capacity is insufficient.
  1. Log in to the CBR console.
    2. In the upper left corner, click and select a region.
    3. Click and choose Storage > Cloud Backup and Recovery.
  2. Locate the target vault and choose More > Expand Capacity in the Operation column.
  3. Enter the capacity to be added. The minimum value is 1 GB.
  4. Click Next. Confirm the settings and click Submit.
  5. Return to the vault list and check that the capacity of the vault has been expanded.
