x-apigateway-backend.httpEndpoints
Meaning: HTTP backend service definition.
Scope of effect: x-apigateway-backend
Example:
paths:
'/users/{userId}':
get:
produces:
- "application/json"
parameters:
- name: "X-Auth-Token"
description: "Authentication token"
type: "string"
in: "header"
required: true
responses:
default:
description: "default response"
x-apigateway-request-type: "public"
x-apigateway-backend:
type: "HTTP"
httpEndpoints:
address: "example.com"
scheme: "http"
method: "GET"
path: "/users"
timeout: 30000
Parameter |
Mandatory |
Type |
Description |
address |
Yes |
Array |
Backend service address. The format is <Domain name or IP address>:[Port number] |
scheme |
Yes |
String |
Backend request protocol. HTTP and HTTPS are supported. |
method |
Yes |
String |
Backend request method. The options include GET, POST, PUT, DELETE, HEAD, OPTIONS, PATCH, and ANY. |
path |
Yes |
String |
Backend request path, which can contain variables. |
timeout |
No |
Number |
Backend request timeout in milliseconds. The range is 1–60,000, and the default value is 5000. |
