Taking an API Offline
You can remove APIs that you do not need from the environments where the APIs have been published.
![](https://support.huaweicloud.com/intl/en-us/ae-ad-1-usermanual-apig/public_sys-resources/notice_3.0-en-us.png)
This operation will cause the APIs to be inaccessible in the environments. Ensure that you have notified users before this operation.
- You have created an API group and API.
- You have published the API.
- Log in to the APIG console.
- Select a gateway at the top of the navigation pane.
- In the navigation pane, choose API Management > API Groups.
- Click the name of the target API group.
- To take one API offline, select the API, and click Take Offline in the upper right.
- To take multiple APIs (≤ 1000) offline, click Batch, select the APIs, and click the Take Offline icon.
- Select the environment from which you want to take the API offline, and click Yes.
Follow-Up Operations
After taking an API offline, delete it to release resources.
