Help Center>
API Gateway>
User Guide (ME-Abu Dhabi Region)>
Monitoring & Analysis>
API Monitoring>
Viewing Metrics
Updated on 2023-05-09 GMT+08:00
Viewing Metrics
Cloud Eye monitors the status of your APIs and allows you to view their metrics.
Viewing Metrics of an API
- Log in to the APIG console.
- Select a gateway at the top of the navigation pane.
- In the navigation pane, choose API Management > API Groups.
- Click a group name.
- In the left pane of the APIs tab, select an API.
- View metrics of the API in the Monitoring area.
- Click More to view more metrics on the Cloud Eye console.
The monitoring data is retained for two days. To retain the data for a longer period, save it to an OBS bucket.
Viewing Metrics of an API group
- In the navigation pane, choose Monitoring & Analysis > API Monitoring.
- Select the target API group and view its metrics.
Parent topic: API Monitoring
