Help Center>
API Gateway>
User Guide (ME-Abu Dhabi Region)>
Getting Started>
Opening APIs>
(Optional) Creating an Environment
Updated on 2023-05-09 GMT+08:00
- In the navigation pane, choose API Management > API Policies. Then click the Environments tab.
- Click Create Environment and set the environment information.
Table 1 Environment information Parameter
Name
Environment name. It is recommended that you enter a name based on naming rules to facilitate search.
Description of the environment.
- Click OK.
Parent topic: Opening APIs
