Help Center/
      API Gateway/
        User Guide (ME-Abu Dhabi Region)/
        Getting Started/
        Opening APIs/
      Creating an API Group
- Log in to the APIG console.
 - In the upper part of the navigation pane, select the gateway.
 - In the navigation pane, choose API Management > API Groups.
 - Choose Create API Group > Create Directly.
Table 1 API group information Parameter
Name
API group name. It is recommended that you enter a name based on naming rules to facilitate search.
Description of the API group.
 - Click OK. The system automatically allocates a debugging domain name to the API group. APIs in the group can be debugged using the domain name.
   Parent topic: Opening APIs
