Updated on 2023-05-09 GMT+08:00
Specifications
Dedicated Gateway Specifications
Table 1 lists the specifications of dedicated API gateways.
Edition |
Maximum Number of Requests per Second |
Basic |
2000 |
Professional |
4000 |
Enterprise |
6000 |
Platinum |
10,000 |
![](https://support.huaweicloud.com/intl/en-us/ae-ad-1-usermanual-apig/public_sys-resources/note_3.0-en-us.png)
- For dedicated gateways, you can adjust the maximum number of requests per second for each API.
- The specifications of dedicated gateways cannot be modified.
- The dedicated gateway specifications are tested under the following conditions:
- Protocol: HTTPS
- Connection type: long connection
- Concurrent requests: 100
- Authentication mode: none
- Size of returned data: 1 KB
- Bandwidth: 10 MB/s
Parent topic: Service Overview
