unix_timestamp
This function is used to convert a date value to a numeric date value in UNIX format.
The function returns the first ten digits of the timestamp in normal UNIX format.
Syntax
unix_timestamp(string timestamp, string pattern)
Parameters
| Parameter | Mandatory | Type | Description |
| timestamp | No | DATE or STRING | Date to be converted The following formats are supported:
| pattern | No | STRING | Format to be converted If this parameter is left blank, the default format yyyy-MM-dd hh:mm:ss is used. The value is a combination of the time unit (year, month, day, hour, minute, and second) and any character.
Return Values
The return value is of the BIGINT type.
- If the value of timestamp is NULL, NULL is returned.
- If both timestamp and pattern are left blank, the timestamp represented by the number of seconds since 1970-01-01 00:00:00 is returned.
Example Code
The value 1692149997 is returned.
select unix_timestamp('2023-08-16 09:39:57') If the current system time is 2023-08-16 10:23:16, 1692152596 is returned.
select unix_timestamp();
The value 1692115200 (2023-08-16 00:00:00) is returned.
select unix_timestamp("2023-08-16 10:56:45", "yyyy-MM-dd"); select timestamp1, unix_timestamp(timestamp1) as date1_unix_timestamp, timestamp2, unix_timestamp(datetime1) as date2_unix_timestamp, timestamp3, unix_timestamp(timestamp1) as date3_unix_timestamp from database_t; output: +------------+-------------------------+-----------------------+---------------------- --+------------------------------------+----------------------------+ | timestamp1| date1_unix_timestamp | timestamp2 | date2_unix_timestamp | timestamp3 | date3_unix_timestamp | +------------+-------------------------+-----------------------+-------------------------+------------------------------------+----------------------------+ | 2023-08-02 | 1690905600000 | 2023-08-02 11:09:14 | 1690945754793 | 2023-01-11 00:00:00.123456789 | 1673366400000 | | 2023-08-03 | 1690992000000 | 2023-08-02 11:09:31 | 1690945771994 | 2023-02-11 00:00:00.123456789 | 1676044800000 | | 2023-08-04 | 1691078400000 | 2023-08-02 11:09:41 | 1690945781270 | 2023-03-11 00:00:00.123456789 | 1678464000000 | | 2023-08-05 | 1691164800000 | 2023-08-02 11:09:48 | 1690945788874 | 2023-04-11 00:00:00.123456789 | 1681142400000 | | 2023-08-06 | 1691251200000 | 2023-08-02 11:09:59 | 1690945799099 | 2023-05-11 00:00:00.123456789 | 1683734400000 | +------------+-------------------------+-----------------------+--------------------------+-----------------------------------+----------------------------+
