shiftleft
This function is used to perform a signed bitwise left shift. It takes the binary number a and shifts it b positions to the left.
Syntax
shiftleft(BIGINT a, BIGINT b)
Parameters
Parameter |
Mandatory |
Type |
Description |
a |
Yes |
DOUBLE, BIGINT, DECIMAL, or STRING |
The value can be a float, integer, or string. If the value is not of the BIGINT type, the system will implicitly convert it to the BIGINT type for calculation. |
b |
Yes |
Return Values
The return value is of the INT type.
If the value of a or b is NULL, NULL is returned.
Example Code
The value 8 is returned.
select shiftleft(1,3);
The value 48 is returned.
select shiftleft(6,3);
select shiftleft(6.123456,3.123456);
The value NULL is returned.
select shiftleft(null,3);
