Help Center/ Cloud Container Engine/ User Guide (ME-Abu Dhabi Region)/ FAQs/ Chart and Add-on/ How Can I Clean Up Residual Resources After the NGINX Ingress Controller Add-on in the Unknown State Is Deleted?
Symptom
The NGINX Ingress Controller add-on is in the unknown state, and after this add-on is uninstalled, residual components still remain.
Involved Kubernetes resources include:
  • Namespace-level resources: secret, ConfigMap, Deployment, Service, Role, RoleBinding, lease, ServiceAccount, and job
  • Cluster-level resources: ClusterRole, ClusterRoleBinding, IngressClass, and ValidatingWebhookConfiguration
Solution
  1. Use kubectl to access the cluster.
  2. Search for related resources.
    className="nginx"
    namespace="kube-system"
    className=`if [[ ${className} == "nginx" ]]; then echo ""; else echo "-${className}";fi`
    kubectl get -n ${namespace} secret sh.helm.release.v1.cceaddon-nginx-ingress${className}.v1 cceaddon-nginx-ingress${className}-admission
    kubectl get -n ${namespace} cm cceaddon-nginx-ingress${className}-controller
    kubectl get -n ${namespace} deploy cceaddon-nginx-ingress${className}-controller cceaddon-nginx-ingress${className}-default-backend
    kubectl get -n ${namespace} svc cceaddon-nginx-ingress${className}-controller-admission cceaddon-nginx-ingress${className}-default-backend cceaddon-nginx-ingress${className}-controller
    kubectl get -n ${namespace} role cceaddon-nginx-ingress${className}
    kubectl get -n ${namespace} rolebinding cceaddon-nginx-ingress${className}
    kubectl get -n ${namespace} lease ingress-controller-leader${className}
    kubectl get -n ${namespace} serviceAccount cceaddon-nginx-ingress${className}
    kubectl get clusterRole cceaddon-nginx-ingress${className}
    kubectl get clusterRoleBinding cceaddon-nginx-ingress${className}
    kubectl get ingressClass ${className}
    kubectl get ValidatingWebhookConfiguration cceaddon-nginx-ingress${className}-admission
    className specifies the name of a controller. namespace specifies the namespace where NGINX Ingress Controller was installed.
  3. Manually delete the residual resources if the preceding resources are present.
