Executing the Pre- or Post-installation Commands During Node Creation
Background
When creating a node, use the pre- or -installation commands to install tools or perform security hardening on the node. This section provides guidance for you to correctly use the pre- or post-installation scripts.
Precautions
- Do not use pre- or post-installation scripts that take a long time to execute.
    The pre-installation script has a 15-minute time limit, while the post-installation script has a 30-minute time limit. If the node is not available within the designated time, the node reclaim process will be initiated. Therefore, do not use pre- or post-installation scripts that take a long time to execute.
- Do not directly use reboot in the script.
    CCE executes the post-installation command after installing mandatory components on a node. The node will be available only after the post-installation command is executed. If you run reboot directly, the node may be restarted before its status is reported. As a result, it cannot reach the running state within 30 minutes, and a rollback due to timeout will be triggered. Therefore, do not use reboot. If you need to restart a node, perform the following operations: - Run shutdown -r <time > in the script to delay the restart. For example, you can run shutdown -r 1 to delay the restart for 1 minute.
- After the node is available, manually restart it.
- Log in to the CCE console. In the navigation pane, choose Clusters. Click the target cluster name to access the cluster console.
- Choose Nodes in the navigation pane, click the Nodes tab, click Create Node in the right corner, and configure the parameters.
- In the Advanced Settings area, enter pre- or post-installation commands.
    For example, you can create iptables rules by running a post-installation command to allow a maximum of 25 TCP data packets to be addressed to port 80 per minute and allow a maximum of 100 data packets to be addressed to the port when the limit is exceeded to prevent DDoS attacks. iptables -A INPUT -p tcp --dport 80 -m limit --limit 25/minute --limit-burst 100 -j ACCEPT   The command example here is for reference only.
- After the configuration, enter the number of nodes to be created and click Next: Confirm.
- Click Submit.
