Draining a Node
After you enable nodal drainage on the console, CCE configures the node to be non-schedulable and securely evicts all pods that comply with Rules for Draining Nodes on the node. Subsequent new pods will not be scheduled to this node.
When a node becomes faulty, nodal drainage quickly isolates the faulty node. The pods evicted from the faulty node will be scheduled by the workload controller to other nodes that are running properly.
To ensure service availability during drainage, specify a disruption budget for your application. Otherwise, the application may become unavailable during pod rescheduling.
- A cluster is available and the cluster version meets the following requirements:
- v1.21: v1.21.10-r0 or later
- v1.23: v1.23.8-r0 or later
- v1.25: v1.25.3-r0 or later
- Versions later than v1.25
- To drain a node as an IAM user, you must have at least one of the following permissions (for details, see Namespace Permissions (Kubernetes RBAC-based)):
- cluster-admin (administrator): read and write permissions on all resources in all namespaces.
- drainage-editor: drain a node.
- drainage-viewer: view the nodal drainage status but cannot drain a node.
When a node is drained, all pods on the node will be safely evicted. However, CCE will take specific actions for pods that meet certain filtering criteria.
Filter Criterion |
Forced Drainage Enabled |
Forced Drainage Disabled |
The status.phase field of the pod is Succeeded or Failed. |
Deletion |
Deletion |
The pod is not managed by the workload controller. |
Deletion |
Drainage cancellation |
The pod is managed by DaemonSet. |
None |
For clusters of v1.23.18-r10, v1.25.16-r0, v1.27.16-r0, v1.28.13-r0, v1.29.8-r0, v1.30.4-r0, or later, if forcible drainage is not used for DaemonSet pods, the default operation is None. |
A volume of the emptyDir type is mounted to the pod. |
Eviction |
The pod is a static pod directly managed by kubelet |
None |
None |
The following operations may be performed on pods during node drainage:
- Deletion: The pod is deleted from the current node and will not be scheduled to other nodes.
- Eviction: The pod is deleted from the current node and rescheduled to another node.
- None: The pod will not be evicted or deleted.
- Drainage cancellation: If a pod on a node cancels drainage, the drainage process of the node is terminated and no pod is evicted or deleted.
Drainage Through the Console
- In the navigation pane, choose Nodes. On the displayed page, click the Nodes tab.
- Locate the target node and choose More > Nodal Drainage in the Operation column.
- In the Nodal Drainage window displayed, set parameters.
- Timeout (s): Node drain tasks automatically fail after the specified timeout expires. A value of 0 indicates that task will not time out.
- Forced Drainage: If this function is enabled, pods managed by DaemonSet will be ignored, and pods with emptyDir volumes and pods not managed by controllers will be deleted. For details, see Rules for Draining Nodes.
- Click OK and wait until the node drainage is complete.
Drainage Using kubectl
- Use kubectl to access the cluster. For details, see Accessing a Cluster Using kubectl.
- Edit the YAML file for drainage.
The following is an example of Drainage-test.yaml:
apiVersion: node.cce.io/v1 kind: Drainage metadata: name: 192.168.1.67-1721616409999 # Drainage resource name spec: nodeName: 192.168.1.67 # Kubernetes name of the node to be drained, which can be obtained by running the kubectl get node command force: true timeout: 0
- nodeName: node to be drained. The parameter value is the node name in Kubernetes, not the name displayed on the console.
You can run the kubectl get node command to obtain a node name in Kubernetes.
- force: whether to forcibly drain a node. Value true means that the drainage is forced, while false means it is not.
- timeout: timeout measured in seconds. Node drain tasks automatically fail after the specified timeout expires. A value of 0 indicates that task will not time out.
- Create drainage resources.
kubectl create -f Drainage-test.yaml
If information similar to the following is displayed, the drainage resources have been created:
drainage.node.cce.io/192.168.1.67-1721616409999 created
- Check the result.
kubectl get drainages 192.168.1.67-1721616409999 -o yaml
If phase is Succeeded, the operation is successful.
apiVersion: node.cce.io/v1 kind: Drainage metadata: creationTimestamp: "2024-07-22T03:12:56Z" generation: 1 name: 192.168.1.67-1721616409999 resourceVersion: "2683143" uid: 3ec131e4-0505-4c88-8255-ef9d0eb02712 spec: force: true nodeName: 192.168.1.67 timeout: 0 status: conditions: - lastTransitionTime: "2024-07-22T03:12:56Z" message: start to drain node reason: Started status: "True" type: Started - lastTransitionTime: "2024-07-22T03:13:26Z" message: node has been drained reason: Succeeded status: "True" type: Finished phase: Succeeded
Drainage Through APIs
- Obtain the token in the region where the cluster is located.
- Based on the API format, find the URL for the node drainage API.
URL of the API for draining a node:
https://{clusterid}.Endpoint/apis/node.cce.io/v1/drainages
- {clusterid}: cluster ID, which can be obtained on the Overview page of the CCE console.
- Endpoint: endpoint of CCE in the region where the cluster is located.
For details about its value, see Regions and Endpoints.
- Use the POST request method and configure request header parameters.
curl --location --request POST 'https://{clusterid}.Endpoint/apis/node.cce.io/v1/drainages' \ --header 'Content-Type: application/json' \ --header 'X-Auth-Token: MIIWvw******' \ --data @Drainage.json
The following table lists the header parameters contained in the request.Table 1 Request header parameters Parameter
Mandatory
Type
Content-Type
Yes
String
Message body type (format), for example, application/json.
X-Auth-Token
Yes
String
Use a token to call the API.
Drainage.json is located in the current directory and contains the following content:
{ "apiVersion": "node.cce.io/v1", "kind": "Drainage", "metadata": { "name": "192.168.1.67-1721616404940" }, "spec": { "nodeName": "192.168.1.67", "force": true, "timeout": 0 } }- nodeName: node to be drained. The parameter value is the node name in Kubernetes, not the name displayed on the console.
Cancellation Through the Console
In clusters of v1.23.16-r0, v1.25.11-r0, v1.27.8-r0, v1.28.6-r0, v1.29.2-r0, or later versions, node drainage can be canceled.
This operation will abort drainage on nodes, but workloads that have been evicted from these nodes will not be automatically migrated back.
- Locate the node that is being drained and click Cancel Drainage.
- In the displayed dialog box, click OK. The node status changes to Drainage cancelled. You can click Enable Scheduling to restore the node to the schedulable state.
Cancellation Using kubectl
- Check drainage resources.
Command output:NAME AGE 192.168.1.67-1721616409999 13s
- Cancel drainage.
kubectl annotate drainages 192.168.1.67-1721616409999 node.cce.io/drainage-disable=true - Check the result.
kubectl get drainages 192.168.1.67-1721616409999 -o yamlIf the command output, phase is changed to Cancelled.
apiVersion: node.cce.io/v1 kind: Drainage metadata: annotations: node.cce.io/drainage-disable: "true" creationTimestamp: "2024-07-22T03:12:56Z" generation: 1 name: 192.168.1.67-1721616409999 resourceVersion: "2689858" uid: 3ec131e4-0505-4c88-8255-ef9d0eb02712 spec: force: true nodeName: 192.168.1.67 timeout: 0 status: conditions: - lastTransitionTime: "2024-07-22T03:12:56Z" message: start to drain node reason: Started status: "True" type: Started - lastTransitionTime: "2024-07-22T03:13:26Z" message: node has been drained reason: Succeeded status: "True" type: Finished - lastTransitionTime: "2024-07-22T03:37:48Z" message: node drainage has been cancelled reason: Cancelled status: "True" type: Cancelled phase: Cancelled
Cancellation Through APIs
URL of the API for canceling node drainage:
https://{clusterid}.Endpoint/apis/node.cce.io/v1/drainages/{drainageName}
- {drainageName}: name of the drainage resource, which can be obtained by running the kubectl get drainages command.
- Use the PATCH request method and configure request header parameters.
curl --location --request PATCH 'https://{clusterid}.Endpoint/apis/node.cce.io/v1/drainages/{drainageName}' \ --header 'Content-Type: application/merge-patch+json' \ --header 'X-Auth-Token: MIIWvw******' \ --data @Drainage-cancel.json
The following table lists the header parameters contained in the request.Table 2 Request header parameters Parameter
Mandatory
Type
Content-Type
Yes
String
Message body type. The value is application/merge-patch+json in PATCH format.
X-Auth-Token
Yes
String
Drainage-cancel.json is located in the current directory and contains the following content:
{ "metadata": { "annotations": { "node.cce.io/drainage-disable": "true" } } }
