hostPath
hostPath is used for mounting the file directory of the host where the container is located to the specified mount point of the container. If the container needs to access /etc/hosts, use hostPath to map /etc/hosts.
  • Avoid using hostPath volumes as much as possible, as they are prone to security risks. If hostPath volumes must be used, they can only be applied to files or directories and mounted in read-only mode.
  • After the pod to which a hostPath volume is mounted is deleted, the data in the hostPath volume is retained.
Mounting a hostPath Volume on the Console
You can mount a path on the host to a specified container path. A hostPath volume is usually used to store workload logs permanently or used by workloads that need to access internal data structure of the Docker engine on the host.
  1. Log in to the CCE console.
  2. When creating a workload, click Data Storage in Container Settings. Click Add Volume and choose hostPath from the drop-down list.
  3. Set parameters for adding a local volume, as listed in Table 1.
    Table 1 Setting parameters for mounting a hostPath volume
    Volume Type
    Select HostPath.
    HostPath
    Path of the host to which the local volume is to be mounted, for example, /etc/hosts.
    HostPath cannot be set to the root directory /. Otherwise, the mounting fails. Mount paths can be as follows:
    • /opt/xxxx (excluding /opt/cloud)
    • /mnt/xxxx (excluding /mnt/paas)
    • /tmp/xxx
    • /var/xxx (excluding key directories such as /var/lib, /var/script, and /var/paas)
    • /xxxx (It cannot conflict with the system directory, such as bin, lib, home, root, boot, dev, etc, lost+found, mnt, proc, sbin, srv, tmp, var, media, opt, selinux, sys, and usr.)
    Do not set this parameter to /home/paas, /var/paas, /var/lib, /var/script, /mnt/paas, or /opt/cloud. Otherwise, the system or node installation will fail.
    Mount Path
    Enter a mount path, for example, /tmp.
    This parameter specifies a container path to which a data volume will be mounted. Do not mount the volume to a system directory such as / or /var/run. Otherwise, containers will be malfunctional. Mount the volume to an empty directory. If the directory is not empty, ensure that there are no files that affect container startup. Otherwise, the files will be replaced, leading to container startup failures or workload creation failures.
    NOTICE:
    If a volume is mounted to a high-risk directory, use an account with minimum permissions to start the container. Otherwise, high-risk files on the host may be damaged.
    Subpath
    Enter the subpath of the storage volume and mount a path in the storage volume to the container. In this way, different folders of the same storage volume can be used in a single pod. tmp, for example, indicates that data in the mount path of the container is stored in the tmp folder of the storage volume. If this parameter is left blank, the root path is used by default.
    Permission
    • Read-only: You can only read the data in the mounted volumes.
    • Read-write: You can modify the data volumes mounted to the path. Newly written data will not be migrated if the container is migrated, which may cause data loss.
  4. After the configuration, click Create Workload.
Mounting a hostPath Volume Through kubectl
  1. Use kubectl to access the cluster.
  2. Create a file named nginx-hostpath.yaml and edit it.
    vi nginx-hostpath.yaml
    The content of the YAML file is as follows. Mount the /data directory on the node to the /data directory in the container.
    apiVersion: apps/v1
    kind: Deployment
      namespace: default
      replicas: 2
      selector:
        matchLabels:
          app: nginx-hostpath
      template:
          labels:
            app: nginx-hostpath
          containers:
            - name: container-1
              image: nginx:latest
              volumeMounts:
                - name: vol-hostpath         # Volume name, which must be the same as the volume name in the volumes field.
                  mountPath: /data           # Location where the storage volume is mounted
          imagePullSecrets:
            - name: default-secret
          volumes:
            - name: vol-hostpath             # Volume name, which can be customized.
              hostPath:
                path: /data                  # Directory location on the host node.
  3. Create a workload.
    kubectl apply -f nginx-hostpath.yaml
