- What's New
- Function Overview
- Product Bulletin
- Billing
- Getting Started
User Guide
- Process of Using APIG
- Creating a User and Granting APIG Permissions
- Creating a Gateway
- Opening APIs
- (Optional) Configuring Authorization for API Calling
- Calling APIs
Managing APIs
- Overview
- Viewing or Modifying API Information
- Configuring Custom API Authentication
- Configuring API Parameter Orchestration Rules
- Customizing Error Response for APIs
- Cloning an API
- Taking an API Offline
- Importing and Exporting APIs
API Design File Extension Definitions
- x-apigateway-auth-type
- x-apigateway-request-type
- x-apigateway-match-mode
- x-apigateway-cors
- x-apigateway-is-send-fg-body-base64
- x-apigateway-any-method
- x-apigateway-backend
- x-apigateway-backend.parameters
- x-apigateway-backend.httpEndpoints
- x-apigateway-backend.httpVpcEndpoints
- x-apigateway-backend.functionEndpoints
- x-apigateway-backend.mockEndpoints
- x-apigateway-backend-policies
- x-apigateway-backend-policies.conditions
- x-apigateway-ratelimit
- x-apigateway-ratelimits
- x-apigateway-ratelimits.policy
- x-apigateway-ratelimits.policy.special
- x-apigateway-access-control
- x-apigateway-access-controls
- x-apigateway-access-controls.policy
- x-apigateway-plugins
- x-apigateway-auth-opt
- x-apigateway-result-normal-sample
- x-apigateway-result-failure-sample
- x-apigateway-authorizer
- x-apigateway-response
- x-apigateway-responses
- x-apigateway-pass-through
- x-apigateway-sample
- x-apigateway-content-type
- x-apigateway-orchestrations
- Configuring API Policies
- Configuring a Credential Policy
- Managing APIG Gateways
- Viewing Metrics and Configuring Alarms
- Viewing Audit Logs
- Shared Gateway (for Existing Users)
Best Practices
- Overview
API Openness
- Selectively Exposing CCE Workloads with a Dedicated Gateway
- Selectively Exposing Service Capabilities of a Data Center Using a Dedicated Gateway
- Exposing Backend Services Across VPCs Using a Dedicated Gateway
- Routing gRPC Service Requests Using a Dedicated Gateway
- Forwarding WebSocket Service Requests Using a Dedicated Gateway
- HTTP-to-HTTPS Auto Redirection with a Dedicated Gateway
- Calling Different Backend Services Using a Dedicated Gateway
- API Authentication
- API Policies
- API Security
- Developer Guide
API Reference
- Before You Start
- API Overview
- Calling APIs
Dedicated Gateway APIs (V2)
- API Group Management
- Environment Management
- Environment Variable Management
- Request Throttling Policy Management
API Management
- Creating an API
- Modifying an API
- Deleting an API
- Publishing an API or Taking an API Offline
- Querying API Details
- Querying APIs
- Verifying the API Definition
- Debugging an API
- Publishing APIs or Taking APIs Offline
- Querying Historical Versions of an API
- Switching the Version of an API
- Querying the Runtime Definition of an API
- Querying API Version Details
- Taking an API Version Offline
- Signature Key Management
- Binding/Unbinding Signature Keys
- Binding/Unbinding Request Throttling Policies
- Excluded Request Throttling Configuration
- App Authorization Management
- Resource Query
- Domain Name Management
- Access Control Policy Management
- Binding/Unbinding Access Control Policies
- Custom Authorizer Management
- API Import and Export
VPC Channel Management
- Creating a VPC Channel
- Updating a VPC Channel
- Deleting a VPC Channel
- Querying VPC Channel Details
- Querying VPC Channels
- Adding or Updating Backend Instances
- Querying Backend Servers of a VPC Channel
- Updating Backend Instances
- Removing a Backend Server
- Enabling Backend Servers
- Disabling Backend Servers
- Modifying VPC Channel Health Check
- Adding or Updating a Backend Server Group of a VPC Channel
- Querying Backend Server Groups of a VPC Channel
- Querying a Backend Server Group of a VPC Channel
- Deleting a Backend Server Group of a VPC Channel
- Updating a Backend Server Group of a VPC Channel
- Monitoring Information Query
- Group Response Management
- Tag Management
- Gateway Feature Management
- Configuration Management
Gateway Management
- Creating a Dedicated Gateway (Pay-Per-Use)
- Querying Dedicated Gateway Details
- Updating a Dedicated Gateway
- Querying the Creation Progress of a Dedicated Gateway
- Updating or Binding an EIP to a Dedicated Gateway
- Unbinding the EIP of a Dedicated Gateway
- Enabling Public Access for a Dedicated Gateway
- Updating the Outbound Access Bandwidth of a Dedicated Gateway
- Disabling Public Access for a Dedicated Gateway
- Enabling Public Inbound Access
- Updating Public Inbound Access Bandwidth of a Gateway
- Disabling Public Inbound Access for a Gateway
- Querying AZs
- Querying Dedicated Gateways
- Deleting a Dedicated Gateway
- Modifying the Specifications of a Pay-Per-Use Gateway
- Querying Gateway Constraints
- VPC Endpoint Management
- Gateway Tag Management
- Microservice Center Management
SSL Certificate Management
- Querying SSL Certificates
- Creating an SSL Certificate
- Binding a Domain Name with SSL Certificates
- Unbinding a Domain Name's SSL Certificates
- Querying Certificate Details
- Deleting an SSL Certificate
- Modifying an SSL Certificate
- Binding an SSL Certificate to a Domain Name
- Unbinding an SSL Certificate from a Domain Name
- Querying Domain Names of an SSL Certificate
Plug-in Management
- Creating a Plug-in
- Modifying a Plug-in
- Deleting a Plug-in
- Querying Plug-ins
- Querying Plug-in Details
- Binding a Plug-in to APIs
- Binding an API with Plug-ins
- Unbinding a Plug-in from All APIs
- Unbinding an API's Plug-ins
- Querying APIs Bound with a Plug-in
- Querying Plug-ins Bound to an API
- Querying APIs to Which a Plug-in Can Be Bound
- Querying Plug-ins That Can Be Bound to an API
Credential Management
- Creating an App
- Modifying an App
- Deleting an App
- Resetting the AppSecret of an App
- Verifying an App
- Querying App Details
- Querying Apps
- Creating an AppCode
- Generating an AppCode
- Deleting an AppCode
- Querying AppCode Details
- Querying AppCodes of an App
- Querying Quotas Associated with a Credential
- Configuring Access Control Settings for an App
- Querying Access Control Details About an App
- Deleting Access Control Settings of an App
Credential Quota Management
- Creating a Credential Quota
- Querying Credential Quota Details
- Querying Credential Quotas
- Modifying a Credential Quota
- Deleting a Credential Quota
- Querying the Credentials Bound to a Specified Quota
- Binding a Credential Quota with Credentials
- Unbinding a Credential Quota from a Credential
- Querying Credentials That Can Be Bound to a Credential Quota
- Asynchronous Task Management
- Orchestration Rule Management
- Gateway Custom Inbound Port Management
Shared Gateway APIs (for Existing Users)
API Management
- Object Model
- Creating an API
- Modifying an API
- Deleting an API
- Publishing an API
- Publishing Multiple APIs or Taking Multiple APIs Offline
- Querying an API List
- Querying Historical API Versions
- Taking an Effective Version of an API Offline
- Querying Details of an API Version
- Debugging an API
- App Management
- Binding Request Throttling Policies
Binding Access Control Policies
- Object Model
- Binding an Access Control Policy to an API
- Querying the List of Access Control Policies Bound to an API
- Querying the List of APIs Bound to an Access Control Policy
- Querying the List of APIs Not Bound to an Access Control Policy
- Unbinding an Access Control Policy from an API
- Unbinding Multiple Access Control Policies from APIs
- Querying Subscription Information in KooGallery
- Resource Query
- Binding Signature Keys
- VPC Channel Management
- Querying Metrics
- OpenAPI
- Appendix
- Change History
- SDK Reference
- Common FAQs
- Product Consulting FAQs
Opening APIs
- Why Can't I Create APIs?
- How Do I Define Response Codes for an API?
- Can I Specify a Private Network Load Balancer Address for the Backend Service?
- Can I Specify the Backend Address as a Subnet IP Address?
- Does APIG Support Multiple Backend Endpoints?
- Can I Bind Private Domain Names for API Access?
- Why Do I Fail to Call an API Across Domains?
- How Do I Use APIG to Open Up Services Deployed on Huawei Cloud?
- Publishing an API
Calling APIs
- What Are the Possible Causes for an API Calling Failure?
- Why Am I Seeing the Error Message "414 Request URI too large" When I Call an API?
- Why Am I Seeing the Error Message "The API does not exist or has not been published in the environment" When I Call an API?
- Why Am I Seeing the Error Message "No backend available" When I Call an API?
- Why Am I Seeing the Error Message "Backend unavailable" or "Backend timeout" When I Invoke the Backend Service?
- Why Am I Seeing the Error Message "Backend domain name resolution failed" When I Invoke the Backend Service?
- Why Am I Seeing the Error Message "Incorrect IAM authentication information" When I Call an API?
- Why Am I Seeing the Error Message "Incorrect app authentication information" When I Call an API?
- Why Doesn't Modification of the backend_timeout Parameter Take Effect?
- Does APIG Have a Limit on the Size of the API Request Body?
- Is There a Limit on the Size of the Response to an API Request?
- How Do I Call an API Using App Authentication in iOS System?
- Why Can't I Create a Header Parameter Named x-auth-token for an API Called Through IAM Authentication?
- Can Mobile Apps Call APIs?
- Can Applications Deployed in a VPC Call APIs?
- Does APIG Support WebSocket Data Transmission?
- How Will the Requests for an API with Multiple Backend Policies Be Matched and Executed?
- How Can I Access Backend Services over Public Networks Through APIG?
API Policies
- Can I Configure the Maximum Number of Concurrent Requests?
- Is the Restriction of 1,000 Requests Per Day to a Debugging Domain Name Applied to Enterprise Accounts?
- Does APIG Have Bandwidth Limits?
- Why Doesn't a Request Throttling Policy Take Effect?
- How Do I Provide an Open API to Specific Users?
- Are Client IP Addresses Verified for Access Control?
- Videos
More Documents
- Getting Started
- Comparing Versions
- Overview
API Management
- Creating an API Group
- Creating an Environment Variable
- Creating a Gateway Response
- Creating an API
- Cloning an API
- CORS
- Debugging an API
- Authorizing API Access
- Publishing an API
Importing and Exorting APIs
- Restrictions and Compatibility
- Importing APIs
- Exporting APIs
Extended Definition
- x-apigateway-cors
- Viewing APIs
- HTTP 2.0
- API Policies
- Credentials
- Monitoring & Analysis
- Gateway Management
- SDKs
- Published API Calling
- Permissions Management
- Auditing
- Common FAQs
API Creation
- How Do I Specify the Host Port for a VPC Channel (or Load Balance Channel)?
- How Do I Set the Backend Address If I Will Not Use a VPC Channel (or Load Balance Channel)?
- How Can I Configure the Backend Service Address?
- What Should I Do After Applying for an Independent Domain Name?
- Why Does an API Failed to Be Called Across Domains?
API Calling
- What Should I Do If an Error Code Is Returned During API Calling?
- What Should I Do If "The API does not exist or has not been published in the environment." Is Displayed?
- Why Am I Seeing the Message "No backend available"?
- What Are the Possible Causes If the Message "Backend unavailable" or "Backend timeout" Is Displayed?
- Why Am I Seeing the Message "Backend domain name resolution failed" When a Backend Service Is Called?
- How Do I Switch the Environment for API Calling?
- What Is the Maximum Size of an API Request Package?
- How Do I Perform App Authentication in iOS System?
- App (Credential) FAQs
- Does APIG Support Persistent Connections?
API Authentication
- Does APIG Support HTTPS Two-Way Authentication?
- How Do I Call an API That Does Not Require Authentication?
- Which TLS Versions Does APIG Support?
- Does APIG Support Custom Authentication?
- Will the Request Body Be Signed for Security Authentication?
- Common Errors Related to IAM Authentication Information
- What Should I Do If the App Authentication Information Is Incorrect?
- API Control Policies
- API Publishing
- API Security
- Other FAQs
- Change History
- Developer Guide (Kuala Lumpur Region)
- Before You Start
- Calling APIs
API Management
- Creating an API
- Modifying an API
- Deleting an API
- Querying APIs
- Debugging an API
- Resource Query
- Tag Management
Gateway Management
- Querying AZs
Plug-in Management
- Querying Plug-ins
- Creating an App
- Modifying an App
- Deleting an App
- Verifying an App
- Querying Apps
- Appendix
- Change History
- Getting Started
- Overview
API Management
- Importing a CCE Workload
- Creating an API
- Creating a gRPC API
- Cloning an API
- CORS
- Debugging an API
- Publishing an API
- Importing APIs
- Exporting APIs
Extended Definition
- x-apigateway-cors
- Viewing APIs
- HTTP 2.0
- API Policies
- Credentials
- SDKs
- Auditing
- Common FAQs
API Creation
API Calling
API Authentication
- API Publishing
- API Security
- Other FAQs
- Change History
- Developer Guide (ME-Abu Dhabi Region)
- Before You Start
- Calling APIs
API Management
- Creating an API
- Modifying an API
- Deleting an API
- Querying APIs
- Debugging an API
- Resource Query
- Tag Management
Gateway Management
- Querying AZs
Plug-in Management
- Querying Plug-ins
- Creating an App
- Modifying an App
- Deleting an App
- Verifying an App
- Querying Apps
- This API is used to creat a credential quota.
- Appendix
- Change History
Best Practices (ME-Abu Dhabi Region)
- Developing a Custom Authorizer with FunctionGraph
- Interconnecting a Dedicated Gateway with WAF
- Request Throttling 2.0 with a Dedicated Gateway
- Two-Factor Authentication with a Dedicated Gateway
- Client Authentication with a Dedicated Gateway
- Invoking an API Policy Backend via Frontend Authentication Parameters (System Parameter)
- Forwarding WebSocket Services Using Dedicated Gateway
- Change History
- User Guide (Paris Region)
Developer Guide (Paris Region)
- Application Scenarios
- Calling APIs Through App Authentication
- Calling APIs Through IAM Authentication
- Creating Signatures for Backend Requests
- Extended Definition
- API Import Precautions
- Examples of Importing APIs
- API Export Precautions
- Change History
API Reference (Paris Region)
- Before You Start
- Calling APIs
- Getting Started
Shared Gateway APIs
API Management
- Object Model
- Registering an API
- Modifying an API
- Deleting an API
- Publishing an API
- Debugging an API
- App Management
- Object Model
- Querying Subscription Information in the Marketplace
- Resource Query
- OpenAPI
- Appendix
- Change History
Dedicated API Gateway User Guide (Paris Region)
- Getting Started
- Overview
API Management
- Creating an API
- CORS
- Debugging an API
- Publishing an API
- Importing APIs
- Exporting APIs
Extended Definition
- x-apigateway-cors
- Viewing APIs
- API Policies
- Credentials
- Auditing
- Common FAQs
API Creation
API Calling
API Authentication
- API Publishing
- API Security
- Other FAQs
- Change History
- Dedicated API Gateway Developer Guide (Paris Region)
Dedicated API Gateway API Reference (Paris Region)
- Before You Start
- Calling APIs
API Management
- Creating an API
- Modifying an API
- Deleting an API
- Querying APIs
- Debugging an API
- Resource Query
- App Management
- Tag Management
Gateway Management
- Querying AZs
- Appendix
- Change History
Third-Party Authorizer
You can configure your own service to authenticate API requests. APIG first invokes this service for authentication, and then invokes the backend service after receiving a success response.
If your gateway does not support this policy, contact technical support to upgrade the gateway to the latest version.
The following figure shows the principle of third-party authentication. After binding a third-party authentication policy to an API, call the API by referring to Calling APIs.
You have understood the guidelines for policy creation and API binding.
Configuration Parameters
Parameter |
Description |
Load Balance Channel |
Whether to connect a third-party authentication service using a load balance channel.
Backend URL |
Timeout (ms) |
Timeout of the authentication service. It cannot exceed the max. timeout of the backend service. View the timeout limit on the Parameters tab of the gateway details page. |
Host Header |
Set this parameter only if a load balance channel is used. Define a host header for requests to be sent to cloud servers associated with the load balance channel. By default, the original host header in each request is used. |
Brute Force Threshold |
IP addresses whose number of third-party authentication failure attempts within 5 minutes exceeds this threshold will be blocked. They will be unblocked after 5 minutes. For example, if an IP address has failed third-party authentication more than the configured threshold in the third minute, the address is blocked, and will be unblocked after 2 minutes. |
Identity Sources |
Parameters to obtain from the original API requests for third-party authentication. Max. 10 headers and 10 query strings. If not specified, all headers and query strings in the original requests will be used. |
Relaxed Mode |
When this option is enabled, APIG accepts client requests even when your authentication service cannot connect or returns an error code starting with "5". |
Allow Original Request Body |
When this option is enabled, the original request body is included for authentication. |
Request Body Size (bytes) |
Available only when Allow Original Request Body is enabled. The value cannot exceed the max. request body size of the gateway. View the request body size limit on the Parameters tab of the gateway details page. |
Allow Original Request Path |
When this option is enabled, the original request path is added to the end of the authentication request path. |
Return Response |
When this option is enabled, the authentication response is returned on failure. |
Allowed Response Headers |
Headers to obtain from the authentication response and send to the backend service, when the authentication is successful. Max. 10 headers. |
Simple Authentication |
When this option is enabled, status codes starting with "2" indicate successful authentication. |
Authentication Result |
Available only when Simple Authentication is disabled. Responses whose headers contain these parameters with the same values indicate successful authentication. |
Blacklist/Whitelist |
When this option is enabled, whether API requests require third-party authentication depends on the configured blacklist or whitelist rules. |
Type |
Parameters |
Define parameters for rule matching.
Rules |
Define conditions for rule matching. Click Add Rule and edit the rule name and conditions. In the Condition Expressions dialog box, select a parameter and operator, and enter a value.
Example Script
{ "auth_request": { "method": "GET", "protocol": "HTTPS", "url_domain": "192.168.10.10", "timeout": 5000, "path": "/", "vpc_channel_enabled": false, "vpc_channel_info": null }, "custom_forbid_limit": 100, "carry_body": { "enabled": true, "max_body_size": 1000 }, "auth_downgrade_enabled": true, "carry_path_enabled": true, "return_resp_body_enabled": false, "carry_resp_headers": [], "simple_auth_mode_enabled": true, "match_auth": null, "rule_enabled": false, "rule_type": "allow" }
