Managing Environments
An API can be called in different environments, such as production, testing, and development environments. RELEASE is the default environment provided by APIG.
Creating an Environment
- Go to the APIG console.
 - Select a dedicated gateway at the top of the navigation pane.
- In the navigation pane, choose API Management > API Policies.
 - Click the Environments tab.
- Click Create Environment and set the environment information.
Table 1 Environment information Parameter
Name
Environment name.
Description of the environment.
 - Click OK.
After the environment is created, it is displayed in the environment list.
Accessing an Environment
You can call an API in the RELEASE environment by using a RESTful API. To access the API in other environments, add the X-Stage header to the request to specify an environment name. For example, add X-Stage:DEVELOP to the request header to access an API in the DEVELOP environment.
   APIG does not support API debugging with environment variables.
Follow-Up Operations
After creating an environment, publish APIs in the environment so that they can be called by API callers.
