Help Center/
      API Gateway/
        User Guide (ME-Abu Dhabi Region)/
        Gateway Management/
      Viewing or Modifying Gateway Information
You can view and modify the configuration of your gateways on the console.
- Go to the APIG console.
- In the navigation pane, choose Gateways.
 - Click Access Console or the name of the target gateway.
 - On the Gateway Information tab, view or modify the configuration of the gateway.
   Parent topic: Gateway Management
