Help Center/
      API Gateway/
        User Guide (ME-Abu Dhabi Region)/
        Getting Started/
        Opening APIs/
      Debugging an API
Debugging an API
- On the APIs tab page, select an API from Creating an API and click Debug.
 - Configure the URL.
 - Click Debug. The API request and response information are displayed at the bottom of the page.
If the API is called successfully, the status code 200 is displayed. Otherwise, rectify the fault by referring to Error Codes.
   Parent topic: Opening APIs
