Help Center/
      API Gateway/
        User Guide (ME-Abu Dhabi Region)/
        Getting Started/
        Calling APIs/
      Creating a Credential and Getting Authorized
- In the navigation pane, choose API Management > Credentials.
 - Click Create Credential and set credential information.
Table 1 Credential information Parameter
Name
Credential name. It is recommended that you enter a name based on naming rules to facilitate search.
Description about the credential.
 - Click OK.
Binding to an API
- In the Operation column of the created credential, click Bind to APIs. Note that only APIs that use app authentication can be bound.
 - Select the environment, API group, and API created in Opening APIs, and click OK.
   Parent topic: Calling APIs
