Help Center/
      API Gateway/
        User Guide (ME-Abu Dhabi Region)/
        Getting Started/
        Opening APIs/
      Publishing an API
Publishing an API
- In the navigation pane, choose API Management > APIs.
 - Locate the API created in Creating an API, and click Publish.
 - Select the environment where the API will be published.
 - Click OK.
   Parent topic: Opening APIs
