Help Center/
      API Gateway/
        User Guide (ME-Abu Dhabi Region)/
        FAQs/
        API Publishing/
      Can I Specify an Environment for API Debugging?
No.
APIG debugs APIs in a specific debugging environment. After debugging is completed, you need to publish your API in an environment, and use code or Postman to add the X-Stage header to specify the environment where you want to call the API.
   Parent topic: API Publishing
