Help Center/
      API Gateway/
        User Guide (ME-Abu Dhabi Region)/
        FAQs/
        API Import and Export/
      Does APIG Provide a Template for Importing APIs from Swagger Files?
        Updated on 2023-05-09 GMT+08:00
The template is being developed.
Currently, you can configure one or two APIs in APIG, and then export them to use as templates.
   Parent topic: API Import and Export
