Help Center/
      API Gateway/
        User Guide (ME-Abu Dhabi Region)/
        FAQs/
        API Publishing/
      Do I Need to Publish an API Again After Modification?
Yes.
After you modify the parameters of a published API, you must publish the API again to synchronize the modifications to the environment.
For details, see section "Publishing an API" in the API Gateway User Guide.
   Parent topic: API Publishing
