minute
This function is used to return the minute (from 0 to 59) of a specified time.
Syntax
minute(string date)
Parameters
| Parameter | Mandatory | Type | Description |
| date | Yes | DATE or STRING | Date that needs to be processed The following formats are supported:
Return Values
The return value is of the INT type.
- If the value of date is not of the DATE or STRING type, the error message "data type mismatch" is displayed.
- If the value of date is of the DATE or STRING type but is not in one of the supported formats, NULL is returned.
- If the value of date is NULL, NULL is returned.
Example Code
The value 54 is returned.
select minute('2023-08-10 10:54:00'); The value 54 is returned.
select minute('10:54:00'); The value NULL is returned.
select minute('20230810105400'); The value NULL is returned.
select minute(null);
