from_utc_timestamp
This function is used to convert a UTC timestamp to a UNIX timestamp in a given time zone.
Syntax
from_utc_timestamp(string timestamp, string timezone)
Parameters
Parameter | Mandatory | Type | Description |
timestamp | Yes | DATE STRING TINYINT SMALLINT INT BIGINT | Time to be converted Date value of the DATE or STRING type, or timestamp of the TINYINT, SMALLINT, INT, or BIGINT type. The following formats are supported: yyyy-mm-dd yyyy-mm-dd hh:mi:ss yyyy-mm-dd hh:mi:ss.ff3 |
timezone | Yes | STRING | Time zone where the time to be converted belongs |
Return Values
The return value is of the TIMESTAMP type.
- If the value of timestamp is not of the DATE or STRING type, the error message "data type mismatch" is displayed.
- If the value of timestamp is of the DATE or STRING type but is not in one of the supported formats, NULL is returned.
- If the value of timestamp is NULL, NULL is returned.
- If the value of timezone is NULL, NULL is returned.
Example Code
The value 1691978400000 is returned, indicating 2023-08-14 10:00:00.
select from_utc_timestamp('2023-08-14 17:00:00','PST'); The value 1691917200000 is returned, indicating 2023-08-13 17:00:00.
select from_utc_timestamp(date '2023-08-14 00:00:00','PST');
The value NULL is returned.
select from_utc_timestamp('2023-08-13',null); Feedback
