datediff
This function is used to calculate the difference between date1 and date2.
Similar function: datediff1. The datediff1 function is used to calculate the difference between date1 and date2 and return the difference in a specified datepart.
Syntax
datediff(string date1, string date2)
Parameters
| Parameter | Mandatory | Type | Description |
| date1 | Yes | DATE or STRING | Minuend of the date difference between date1 and date2. The following formats are supported:
| date2 | Yes | DATE or STRING | Subtrahend of the date difference between date1 and date2. The following formats are supported:
Return Values
The return value is of the BIGINT type.
- If the values of date1 and date2 are not of the DATE or STRING type, the error message "data type mismatch" is displayed.
- If the values of date1 and date2 are of the DATE or STRING type but are not in one of the supported formats, NULL is returned.
- If the value of date1 is smaller than that of date2, the return value is a negative number.
- If the value of date1 or date2 is NULL, NULL is returned.
Example Code
The value 10 is returned.
select datediff('2023-06-30 00:00:00', '2023-06-20 00:00:00'); The value 11 is returned.
select datediff(date '2023-05-21', date '2023-05-10');
The value NULL is returned.
select datediff(date '2023-05-21', null);
