OPTIMIZE
Function
This command optimizes the data layout in storage to improve query speed.
Precautions
- Since optimization is time-consuming, you need to determine the frequency of running OPTIMIZE based on the trade-off between better end-user query performance and the optimization computation time.
- To optimize partitioned tables, set spark.sql.forcePartitionPredicatesOnPartitionedTable.enabled to false.
Syntax
OPTIMIZE [database_name.]table_name
[ WHERE boolExpression]
Z-ordering:
ZORDER BY (columnList);
Parameter Description
| Parameter | Description |
| database_name | Name of the database, consisting of letters, numbers, and underscores (_) |
| table_name | Name of the table in the database, consisting of letters, numbers, and underscores (_) |
| boolExpression | Filter condition expression |
| columnList | List of fields specified for z-ordering, and the Z-order columns should be different from the partition columns. |
Required Permissions
- SQL permissions
| Permission Description |
| UPDATE permission on a table |
- Fine-grained permission: dli:table:update
- Metadata services provided by LakeFormation. Refer to the LakeFormation documentation for details on permission configuration.
Examples
OPTIMIZE delta_table0; optimize delta_table0 where dt >= '2020-01-01'; OPTIMIZE delta_table0 WHERE dt >= current_timestamp() - INTERVAL 1 day ZORDER BY (price);
System Response
Display the success or failure of the command execution in the driver logs and the client.
