Halaman ini belum tersedia dalam bahasa lokal Anda. Kami berusaha keras untuk menambahkan lebih banyak versi bahasa. Terima kasih atas dukungan Anda.
On this page
Show all
Using Delta to Submit a Spark Jar Job in DLI
Updated on 2025-01-09 GMT+08:00
1. Add the following dependencies:
<dependency>
    <groupId>io.delta</groupId>
    <artifactId>delta-core_2.12</artifactId>
    <version>2.3.0</version>
</dependency>
2. Add the following parameters to SparkSession:
.config("spark.sql.extensions", "io.delta.sql.DeltaSparkSessionExtension")
.config("spark.sql.catalog.spark_catalog", "org.apache.spark.sql.delta.catalog.DeltaCatalog")
3. Write code (through SQL or API).
(1) SQL development example is as follows. For specific SQL syntax, refer to "Delta SQL Syntax Reference".
public static void main( String[] args )
    SparkSession spark = SparkSession
            .builder()
            .enableHiveSupport()
            .appName("DeltaDemo")
            .getOrCreate();
    String sql_create = "CREATE TABLE if not exists dligms.deltaTest1012 (\n" +
            "  id int,\n" +
            "  name string,\n" +
            "  start_year int,\n" +
            "  class string\n" +
            ") USING DELTA\n" +
            " partitioned by(start_year, class)\n" +
            " location 'obs://bucket_name/path/deltaTest1012'";
    spark.sql(sql_create);
    String sql_insert = "insert into dligms.deltaTest1012 values\n" +
            "(1, 'zhangsan', 2024, 'whlg0905')," +
            "(2, 'lisi', 2024, 'whlg0905')," +
            "(3, 'wangwu', 2024, 'whlg0905')," +
            "(4, 'zhaoliu', 2024, 'whlg0905')";
    spark.sql(sql_insert);
    String sql_select = "select * from dligms.deltaTest1012";
    spark.sql(sql_select).show();
    spark.stop();
(2) API development example is as follows (Java).
            .builder()
            .getOrCreate();
    DeltaTable.createIfNotExists(spark)
            .tableName("deltaJava1011")
            .addColumn("id", "INT")
            .addColumn("name", "STRING")
            .addColumn("start_year", "INT")
            .addColumn("class", "STRING")
            .partitionedBy("start_year", "class")
            .location("obs://bucket_name/path/deltaTest1011")
            .execute();
    Dataset<Row> data = spark.read().format("csv")
            .option("header", "true")
            .option("inferSchema", "true")
            .load("obs://bucket_name/path/export/test1011/");
    data.write().insertInto("deltaJava1011");
    spark.stop();
4. Compile and package the code, and then run the job.
Kami menggunakan cookie untuk meningkatkan kualitas situs kami dan pengalaman Anda. Dengan melanjutkan penelusuran di situs kami berarti Anda menerima kebijakan cookie kami. Cari tahu selengkapnya
