Creating an Endpoint
MaaS allows users to create endpoints. By invoking models through an endpoint name (in the model parameter), users can achieve traffic routing and fine-grained management across different business scenarios or model versions.
For LLM inference, the endpoint is the key access point for invoking a model. Developers can send API inference requests using a specified model ID, enabling fast access and flexible invocation.
During the development and operation of AI applications, enterprises and developers encounter issues such as chaotic inference service call management, difficulties in throttling, and ambiguous cost accounting. Multiple business lines might share the same inference service, leading to resource competition and unstable service performance. Additionally, the lack of effective call restrictions makes it challenging to track the resource consumption of each business line.
MaaS provides endpoints that let users create independent entry points, set rate-limiting rules, and track fees precisely by endpoint name. This helps manage inference resources effectively and optimize usage costs.
- This function is only available in the CN-Hong Kong regions. Resources cannot be called across regions.
- This function allows you to create custom endpoints based exclusively on built-in services.
- The upper left corner of the Endpoints tab displays the number of remaining endpoints you can create.
- Each endpoint must have a unique name under an account. A deleted endpoint name cannot be used when you create a new endpoint.
- After an endpoint is created, the model service cannot be modified.
- The created endpoints must comply with the rules and specifications of the platform and cannot be called in violation of regulations.
Billing
Endpoints are free to create. However, you may be charged for calling the model service or using resources. Check service costs in the Billing Center by endpoint name.
- Calling a custom MaaS endpoint: billed by MaaS. Token-based billing is supported. For details, see Billing Items for MaaS Built-in Model Services.
- Log in to the MaaS console and select the target region on the top navigation bar.
- In the navigation pane on the left, choose Model Inference > Real-Time Inference. Click the Endpoints tab. You can view your remaining endpoint quota in the upper left corner.
- Click the Endpoint tab and click Create Endpoint in the upper right corner of the page.
- On the Create Endpoint dialog box, configure parameters.
- On the right of the page, view the configuration summary, select I have read and agree to MaaS Service Statement, confirm the billing information at the bottom of the page, and click Create Now.
- Once you create the endpoint, its details appear in the Endpoint tab. From there, you can see that its status is In use and call or experience it online. Figure 1 Endpoint created
To check bill details by ID, click
next to the endpoint resource ID to copy the ID. Go to the Billing Center, choose Billing > Transactions and Detailed Bills, and click Bill Details.Figure 2 Copying an ID
Viewing Endpoint Details
- On the MaaS console, choose . On the displayed page, click the Endpoints tab. In the Endpoint Name/Resource ID column of the target endpoint, click the endpoint name or resource ID. The Overview page is displayed by default. You can view details about the endpoint, including basic information, billing information, rate limiting information, and more configurations. For details about the parameters, see Table 2.
Table 2 Parameters about an endpoint Parameter
Basic information
Endpoint Name
Name of an endpoint.
ID
ID of an endpoint.
Model
Model selected for the endpoint. Click a model name to view the model information.
Source
Source of the model selected for the endpoint.
Currently, MaaS and ModelArts are supported.
Model Parameter
Model parameter selected for the endpoint.
Created At
Time when an endpoint was created.
Description of an endpoint.
Billing Information
Billing Mode
Billing mode of the endpoint. It is token-based billing. For details, see Table 1.
Inference Price
Inference pricing unit. You can switch between 1M tokens and 1K tokens.
Flow Control
Model Flow Limiting
This parameter is displayed only when Select Model is set to MaaS.
After you select a built-in model, the total traffic limit for the model service under the current account is displayed.
- Requests Per Minute (RPM): The number of requests processed per minute.
- Tokens Per Minute (TPM): The number of input and output tokens processed per minute.
Endpoint Flow Control
You can manually set the traffic limit for an endpoint. If the combined rate limit of all endpoints accessing the same model under an account equals the model's total quota, it effectively prevents competition for traffic allocation among different endpoints.
- You can configure different RPM and TPM traffic controls for each endpoint, as long as they stay within your account's traffic limits.
- The values of RPM and TPM must be positive integers.
More Configurations
ModelArts Guard
Displays the current status of the content safety guardrails. It is On or Off.
Implicit Watermark
This parameter is displayed only when Select Model is set to MaaS and a built-in video or image generation service is selected.
This function is disabled by default. Once enabled, you must add metadata-based implicit identifiers to AI-generated content.
Explicit Watermark
This function is disabled by default. Once enabled, model outputs will include an AI watermark.
- Endpoints can be edited, deleted, enabled, disabled, and called via API.
- To check bill details by ID, click
next to the endpoint resource ID to copy the ID. Go to the Billing Center, choose Billing > Transactions and Detailed Bills, and click Bill Details. - You can also click the
icon next to the model parameter to copy the model parameter. On the API Calling tab page, you can call different access points based on different model parameters.
- Click the View API Call Description tab to view the process of calling an endpoint. For details, see Calling an Endpoint.
- Click the Monitoring tab to view the call details of the endpoint.
- On the Monitoring tab, select the time range, time granularity, calling method, and IP address as required.
Table 3 Filters for endpoint monitoring Parameter
Time Range
Service call statistics can be viewed for today, yesterday, the past 3, 7, or 14 days, or across a custom date range.
Time range and precision filtering rules:- For time ranges of 1–2 days, metrics can be queried at minute or hour precision.
- For time ranges of 3–7 days, metrics can be queried at hour or day precision.
- For time ranges longer than 7 days, metrics can be queried at day precision only.
Time granularity
The calling statistics can be collected by minute or hour.
Calling Method
API key calls and online experience are supported.
- By default, all API keys are used to authenticate calls to a model service on MaaS. You can choose specific ones if needed.
IP Address
The client source IP address (public IP) that has generated calls is derived from the http_x_forwarded_for field in the APIG logs. When this field contains multiple values, the system will use the first value; if the field value is -, it will be displayed as an empty string.
The IP address is displayed by default as All, but you can also select specific IP addresses as needed.
- Usage: Track endpoints' token usage to prevent overuse.
Table 4 Usage metrics Parameter
Completed Tasks
Number of completed tasks at the endpoint.
Total Inferences
Number of inferences at the endpoint.
Total Requests
The total number of requests at the endpoint.
Total Tokens Used (K Tokens)
The total number of tokens used by the endpoint within each unit of time.
TPM (K Tokens/Minute)
RPM
QPS
The number of queries processed per second. When Time Precision is set to By the minute, the value displayed is the peak QPS recorded during that minute.
Input Tokens (K Tokens)
The length of input tokens.
- AVG: The average length of input tokens.
- MAX: The maximum length of input tokens.
- P50: 50% of the input tokens are below this value.
- P80: 80% of the input tokens are below this value.
- P90: 90% of the input tokens are below this value.
- P99: 99% of the input tokens are below this value.
Output Tokens (K Tokens)
The length of output tokens.
- AVG: The average length of output tokens.
- MAX: The maximum length of output tokens.
- P50: 50% of the output tokens are below this value.
- P80: 80% of the output tokens are below this value.
- P90: 90% of the output tokens are below this value.
- P99: 99% of the output tokens are below this value.
- Performance metrics: View performance metrics to identify opportunities for improvement.
Table 5 Performance metrics Parameter
Average Generation Time (s)
The average time taken to generate each image/video.
Average Response Latency (ms)
The end-to-end latency of successful requests per unit time
- AVG: The average end-to-end latency.
- MAX: The maximum end-to-end latency.
- P50: 50% of the end-to-end latencies are below this value.
- P80: 80% of the end-to-end latencies are below this value.
- P90: 90% of the end-to-end latencies are below this value.
- P99: 99% of the end-to-end latencies are below this value.
Time to First Token (ms)
The time from receiving a request to generating the first output token. The statistics are collected only for streaming responses. Due to model version constraints, certain versions cannot display these metrics in non-streaming scenarios. Upgrade to the latest version to view these metrics.
- AVG: The average TTFT.
- MAX: The maximum TTFT.
- P50: 50% of the TTFTs are below this value.
- P80: 80% of the TTFTs are below this value.
- P90: 90% of the TTFTs are below this value.
- P99: 99% of the TTFTs are below this value.
TPOT (ms)
The interval between two output tokens. The statistics are collected only for streaming responses. Due to model version constraints, certain versions cannot display these metrics in non-streaming scenarios. Upgrade to the latest version to view these metrics. AVG: The average TPOT.
- MAX: The maximum TPOT.
- P50: 50% of the TPOTs are below this value.
- P80: 80% of the TPOTs are below this value.
- P90: 90% of the TPOTs are below this value.
- P99: 99% of the TPOTs are below this value.
Average Task Processing Duration (min)
Average time spent on processing tasks.
- Cache: View the cache hit metrics of an endpoint to evaluate the system performance.
Table 6 Cache hit metrics Parameter
Cache Hits (K Tokens)
The total number of tokens served from the cache at the endpoint.
Cache Hit Rate (%)
The proportion of input tokens served from the endpoint cache, expressed as a percentage of total input tokens.
- Troubleshooting: Quickly identify issues such as sudden increases in calls, abnormal consumption, and call failures during specific time periods.
Table 7 Abnormal metrics Parameter
Request Failure Rate (%)
The proportion of failed requests to the total number of requests.
Total Failed Requests
Indicates the number of failed requests. An error message is displayed when a request fails.
Inference Failure Rate (%)
The proportion of failed inferences to the total number of inferences.
- For more information, see Viewing the Call Data and Monitoring Metrics of Real-Time Inference on MaaS.
Calling an Endpoint
An endpoint can be called only when it is in the In use status. The content generated by AI through service calls does not reflect the views of MaaS. The platform does not guarantee the legality, authenticity, or accuracy of the content and assumes no legal liability.
- On the MaaS console, choose Model Inference > Real-Time Inference and click the Endpoints tab. In the Operation column of the target endpoint, click API Calling.
- On the View API Call Description page, obtain the API key as prompted, copy the call example, replace the API information and API key, and call the API.
- The model Parameter column in the Endpoint tab shows the model's name used in the code during service calls. You can call different endpoints based on different model parameters.
- For details about how to create an API key, see Creating an API Key.
- For details about the parameters in the call example, see MaaS Standard API V2.
Managing an Endpoint
You can view call data and metric data, and edit, enable, or disable endpoints.
- What should I do if the number of endpoints I have created reaches the limit?
You can delete the endpoints that are no longer needed and then create new ones.
- How can I determine the number of tokens consumed?
On the Call Statistics page, check the total number of tokens used, number of input tokens, and number of output tokens. For details, see Viewing the Call Statistics of an Endpoint.
- How long does it take for changes to the traffic limiting settings of an endpoint to take effect?
After you save the changes, the traffic limiting settings will take effect immediately, and subsequent calls will be executed according to the new rules.
- What should I do if the billing status of my endpoint changes to invalid?
If the billing status of your endpoint becomes invalid, it indicates that the resource was frozen due to account arrears and exceeded the resource retention period, resulting in deletion. You may proceed to delete this endpoint and recreate it as needed.
