MaaS Standard API V1
MaaS provides powerful real-time inference. You can call built-in model services directly or deploy models on dedicated instances. This chapter describes the specifications for calling chat APIs.
MaaS Standard API V1 is no longer evolving; prioritize the use of MaaS Standard API V2.
This function is only available in the CN-Hong Kong region.
API Information
| Parameter | Description | Example Value |
| API URL | API URL for calling the model service. | https://api-ap-southeast-1.modelarts-maas.com/v1/chat/completions |
| model | model parameter in an API call | For details about the options of model, see Supported Models. |
Supported Models
You can log in to the MaaS console and enable the following models on the Model Inference > Real-Time Inference > Built-in Services page. On the model details page in the Model Square, you can view detailed information about the models.
| Model | Version | Supported Region | Value of model |
| DeepSeek | DeepSeek-V3.1 | CN-Hong Kong | deepseek-v3.1-terminus |
| DeepSeek-V3 | CN-Hong Kong | DeepSeek-V3 | |
| DeepSeek-V3.2 | CN-Hong Kong | deepseek-v3.2 | |
| DeepSeek-R1-0528 | CN-Hong Kong | deepseek-r1-250528 |
Creating a Chat Request
- Authentication description
MaaS inference services support API key authentication. The authentication header is in the following format:
'Authorization': 'Bearer API key of the region where the service is deployed'
- The request and response parameters are as follows.
Table 2 Request parameters Parameter
Mandatory
Default Value
Type
model
Yes
None
Str
Model to call. For details about the value, see Table 1.
messages
Yes
N/A
Array
Input question. role shows the role, and content shows the dialog content. Example:
"messages": [ {"role": "system","content": "You are a helpful AI assistant."}, {"role": "user","content": "Which number is larger, 9.11 or 9.8?"} ]For more information, see Table 3.
messages.prefix
No
false
Boolean
Controls whether to enable continuation mode. In this mode, the user provides a message starting with assistant, and the model completes the rest based on that beginning and the input instruction.
To use this feature, ensure that the last message in the messages list has the role set to assistant and the prefix parameter set to true. Example:
messages = [ {"role": "user", "content": "Write a snippet of Python code"}, {"role": "assistant", "content": "```python\n", "prefix": True} ]stream_options
No
None
Object
Specifies whether to display the number of used tokens during streaming output. This parameter is only valid when stream is set to True. You need to set stream_options to {"include_usage": true} to print the number of tokens used. For more information, see Table 4.
max_tokens
No
None
Int
Maximum number of tokens that can be generated for the current task, including tokens generated by the model and reasoning tokens for deep thinking.
top_k
No
-1
Int
The candidate set size determines the sampling range during generation. For example, setting it to 50 means only the top 50 scoring tokens are sampled at each step. A larger size increases randomness; a smaller one makes the output more predictable.
top_p
No
1.0
Float
Nucleus sampling. It keeps only the words with combined probabilities above the threshold p and removes the rest. These selected words are then normalized and sampled again.
Lower settings reduce word options, making outputs focused and cautious. Higher settings expand word choices, creating varied and creative outputs.
Adjust either temperature or top_p separately for best results, not both at once.
Value range: 0 to 1. The value 1 indicates that all tokens are considered.
temperature
No
1.0
Float
Model sampling temperature. The higher the value, the more random the model output; the lower the value, the more deterministic the output.
Recommended value of temperature: 0.6 for DeepSeek-V3 and Qwen3 series, and 0.2 for Qwen2.5-VL series.
stop
No
None
None/Str/List
A list of strings used to stop generation. The output does not contain the stop strings.
For example, if the value is set to ["You," "Good"], text generation will stop once either You or Good is reached.
stream
No
False
Bool
Controls whether to enable streaming inference. The default value is False, indicating that streaming inference is disabled.
n
No
Int
Number of responses generated for each input message.
- If beam_search is not used, the recommended value range of n is 1 ≤ n ≤10. If n is greater than 1, ensure that greedy_sample is not used for sampling, that is, top_k is greater than 1 and temperature is greater than 0.
- If beam_search is used, the recommended value range of n is 1 < n ≤ 10. If n is 1, the inference request will fail. NOTE:
- For optimal performance, keep n at 10 or below. Large values of n can significantly slow down processing. Inadequate video RAM may cause inference requests to fail.
- You cannot set n higher than 1 for and DeepSeek-V3.
use_beam_search
No
False
Bool
Controls whether to use beam_search to replace sampling.
When this parameter is used, the following parameters must be configured as required:
- n: > 1
- top_p: 1.0
- top_k: -1
- temperature: 0.0 NOTE:
presence_penalty
No
0.0
Float
Applies rewards or penalties based on the presence of new words in the generated text. The value range is [-2.0,2.0].
frequency_penalty
No
0.0
Float
Applies rewards or penalties based on the frequency of each word in the generated text. The value range is [-2.0,2.0].
length_penalty
No
1.0
Float
Imposes a larger penalty on longer sequences in a beam search process.
- top_k: -1
- use_beam_search: true
- best_of: > 1
NOTE:You cannot set length_penalty for DeepSeek-V3.
thinking
No
object
Controls whether to enable or disable the deep thinking mode for a model.
Default value: N/A
thinking.type
Yes
string
- enabled: The thinking mode is enabled. The model must think before answering.
- disabled: The thinking mode is disabled. The model directly answers questions without thinking.
Default value: The default value varies depending on the model. You can log in to the MaaS console and view the description of the deep thinking mode in the Version area on the Model Square > Model Details page.
Figure 1 Checking the deep thinking mode
Table 4 Request parameter stream_options Parameter
Mandatory
Default Value
Type
include_usage
No
true
Bool
Specifies whether the streaming response outputs token usage information.
- true: Each chunk outputs a usage field that shows the total token usage.
- false: The token usage is not displayed.
Table 5 Response parameters Parameter
Type
id
Str
Unique ID of the request.
object
Str
chat.completion type: Multi-turn dialogs are returned.
created
Int
Timestamp.
model
Str
Model to call.
choices
Array
Model output, including the index and message parameters. In message:
- content is the model's final reply.
- reasoning content is the model's deep thinking content (for DeepSeek models only).
usage
Object
Statistics on tokens consumed by the request:
- This parameter is returned by default for non-streaming requests.
- This parameter is returned by default for streaming requests. Each chunk outputs a usage field that shows the token usage.
Parameters:
- prompt tokens: number of input tokens.
- completion tokens: number of output tokens.
- total tokens: total number of tokens.
prompt_logprobs
Float
Log probability. You can use this to measure the model's confidence in its output or to explore other options the model provides.
DeepSeek-V3 Text Generation (Non-Streaming) Request Example
This section demonstrates the basic non-streaming usage of a text generation model, using the DeepSeek-V3 model as an example to request a text response via a Python script, cURL command, or OpenAI SDK.
- Python request example:
import requests import json if __name__ == '__main__': url = "https://api-ap-southeast-1.modelarts-maas.com/v1/chat/completions" # API address api_key = "MAAS_API_KEY" # Replace MAAS_API_KEY with the obtained API key. # Send a request. headers = { 'Content-Type': 'application/json', 'Authorization': f'Bearer {api_key}' } data = { "model":"deepseek-v3", # Model name "messages": [ {"role": "system", "content": "You are a helpful assistant."}, {"role": "user", "content": "Hello"} ] } response = requests.post(url, headers=headers, data=json.dumps(data), verify=False) # Print result. print(response.status_code) print(response.text) - cURL request example:
curl -X POST "https://api-ap-southeast-1.modelarts-maas.com/v1/chat/completions" \ -H "Content-Type: application/json" \ -H "Authorization: Bearer $MAAS_API_KEY" \ -d '{ "model": "deepseek-v3", "messages": [ {"role": "system", "content": "You are a helpful assistant."}, {"role": "user", "content": "Hello"} ] }' - OpenAI SDK request example:
from openai import OpenAI base_url = "https://api-ap-southeast-1.modelarts-maas.com/v1" # API address api_key = "MAAS_API_KEY" # Replace MAAS_API_KEY with the obtained API key. client = OpenAI(api_key=api_key, base_url=base_url) response = client.chat.completions.create( model="deepseek-v3", # Model name messages=[ {"role": "system", "content": "You are a helpful assistant"}, {"role": "user", "content": "Hello"} ] ) print(response.choices[0].message.content)
DeepSeek-V3 Text Generation (Streaming) Request Example
This section demonstrates the basic streaming usage of a text generation model, using the DeepSeek-V3 model as an example to request a text response via a Python script or cURL command.
from openai import OpenAI base_url = "https://api-ap-southeast-1.modelarts-maas.com/v1" # API address api_key = "MAAS_API_KEY" # Replace MAAS_API_KEY with the obtained API key. client = OpenAI(api_key=api_key, base_url=base_url) response = client.chat.completions.create( model="deepseek-v3", # Model name messages=[ {"role": "system", "content": "You are a helpful assistant"}, {"role": "user", "content": "Hello"} ], stream = True ) for chunk in response: if not chunk.choices: continue print(chunk.choices[0].delta.content, end="") - cURL request example:
curl -X POST "https://api-ap-southeast-1.modelarts-maas.com/v1/chat/completions" \ -H "Content-Type: application/json" \ -H "Authorization: Bearer $MAAS_API_KEY" \ -d '{ "model": "deepseek-v3", "messages": [ {"role": "system", "content": "You are a helpful assistant."}, {"role": "user", "content": "Hello"} ], "stream": true, "stream_options": { "include_usage": true } }'
DeepSeek-V3.1 Text Generation (Non-Streaming) Request Example
This section demonstrates the basic non-streaming usage of a text generation model, using the DeepSeek-V3.1 model as an example to request a text response via a Python script, cURL command, or OpenAI SDK.
import requests import json if __name__ == '__main__': url = "https://api-ap-southeast-1.modelarts-maas.com/v1/chat/completions" # API address api_key = "MAAS_API_KEY" # Replace MAAS_API_KEY with the obtained API key. # Send a request. headers = { 'Content-Type': 'application/json', 'Authorization': f'Bearer {api_key}' } data = { "model": "deepseek-v3.1-terminus", # Model "messages": [ {"role": "system", "content": "You are a helpful assistant."}, {"role": "user", "content": "Hello"} ], "chat_template_kwargs": { "thinking": True # Specifies whether to enable deep thinking. It is disabled by default. } } response = requests.post(url, headers=headers, data=json.dumps(data), verify=False) # Print result. print(response.status_code) print(response.text) - cURL request example:
curl -X POST "https://api-ap-southeast-1.modelarts-maas.com/v1/chat/completions" \ -H "Content-Type: application/json" \ -H "Authorization: Bearer $MAAS_API_KEY" \ -d '{ "model": "deepseek-v3.1-terminus", "messages": [ {"role": "system", "content": "You are a helpful assistant."}, {"role": "user", "content": "Hello"} ], "chat_template_kwargs": { "thinking": true } }' - OpenAI SDK request example:
from openai import OpenAI base_url = "https://api-ap-southeast-1.modelarts-maas.com/v1" # API address api_key = "MAAS_API_KEY" # Replace MAAS_API_KEY with the obtained API key. client = OpenAI(api_key=api_key, base_url=base_url) response = client.chat.completions.create( model="deepseek-v3.1-terminus", # Model messages=[ {"role": "system", "content": "You are a helpful assistant"}, {"role": "user", "content": "Hello"}, ], extra_body={ "chat_template_kwargs": { "thinking": True # Specifies whether to enable deep thinking. It is disabled by default. } } ) print(response.choices[0].message.content)
Response Example
"id":"chat-71406e38b0d248c9b284709f8435****",
"object":"chat.completion",
"created":1740809549,
"choices":[
"index":0,
"message":{
"role":"assistant",
"content":"\n\n Compare 9.11 and 9.8.:\n\n1. **Compare the integer part**: The integer part of both is 9, which is equal.\n2. **Compare the tenths place**:\n - The tenths place of 9.11 is **1**\n - 9.8 can be considered as 9.80, and its tenths place is **8**\n - **8 > 1**, so 9.8 is larger.\n\n**Conclusion**:\n**9.8 > 9.11**\n(When comparing decimals, line up the digits and compare them directly.)",
"reasoning_content": "Well, I now need to compare 9.11 and 9.8 which is larger. First of all, I have to recall the method of comparing decimals. When comparing decimals, start by comparing the integer parts. If the integer parts are the same, compare the tenths and hundredths of the decimal parts in sequence until the larger number is determined.\n\nThe integer parts of the two numbers are both 9, so they are the same. Next, compare the tenths. The tenth digit of 9.11 is 1, while the tenth digit of 9.8 is 8. This can be problematic, as some people might directly treat 9.8 as 9.80, or focus on comparing the digits in the tenths place.\n\nNow, comparing the tenths place, 9.8 has an 8, while 9.11 has a 1. Clearly, 8 is greater than 1. So, should we conclude that 9.8 is greater than 9.11? \n\n However, it is important to note that some people might incorrectly assume that the more decimal places a number has, the larger its value. But this is not true; for instance, 0.9 is greater than 0.8999. Thus, having more decimal places does not necessarily mean a larger value. \n\n Additionally, the decimal parts of the two numbers can be aligned to have the same number of digits for comparison. For instance, 9.8 can be written as 9.80, where the tenths place is 8 and the hundredths place is 0. On the other hand, for 9.11, the tenths place is 1 and the hundredths place is 1. Since 8 in the tenths place is greater than 1, 9.80 (which is 9.8) is greater than 9.11.\n\nTherefore, the final conclusion is that 9.8 is larger than 9.11.\n",
"tool_calls":[]
"logprobs":null,
"finish_reason":"stop",
"stop_reason":null
"usage":{
"prompt_tokens":21,
"total_tokens":437,
"completion_tokens":416
"prompt_logprobs":null
} Feedback
