Updated on 2026-03-26 GMT+08:00
Protection Rules
After the firewall is enabled, CFW allows all traffic by default. You can configure different protection rules to let the firewall block unauthorized traffic, implementing multi-dimensional traffic isolation and control.
Protected Objects
  • Objects that can be protected: 5-tuples, IP address groups, geographical locations, domain name groups, and domain names
  • Network types: EIPs and private IP addresses (only supported by the professional edition)
Protective Actions
A protective action can be Allow or Block. If the packets of a traffic package match a protection rule, CFW performs the action specified in the rule.
  • Allow: Traffic is forwarded.
  • Block: Traffic is not forwarded. Note the following when configuring a blocking rule:
    1. You are advised to preferentially configure specific IP addresses (for example, 192.168.10.5) to reduce network segment configurations and avoid improper blocking.
    2. Exercise caution when configuring protection rules to block reverse proxy IP addresses, such as the CDN, Advanced Anti-DDoS, and WAF back-to-source IP addresses. You are advised to configure protection rules or whitelist to permit reverse proxy IP addresses.
    3. Blocking forward proxy IP addresses (such as company egress IP addresses) can have a large impact. Exercise caution when configuring protection rules to block forward proxy IP addresses.
    4. When configuring region protection, take possible EIP changes into consideration.
      A protection rule with its source or destination set to a region (geographical location) takes effect only for IPv4 protected objects.
Wildcard Rules
Input
Source/Destination
0.0.0.0/0
All IP addresses
Domain name
www.example.com
Domain name www.example.com
*.example.com
All domain names ending with example.com, for example, test.example.com
Service - Source port or destination port
1-65535
All ports
80-443
All ports in the range 80 to 443
  • 80
  • 443
Ports 80 and 443
Examples of Protection Rule Configuration
In this example, two protection rules are configured. One rule blocks all traffic and has the lowest priority. The other rule allows the traffic from a specified IP address and has the highest priority. Configure other parameters as needed. For details about parameter configuration, see Blocking or Allowing Traffic by Adding Protection Rules.
  • One of them blocks all traffic and has the lowest priority. Configure the following parameters as suggested, and configure other parameters as needed.
    Figure 1 Blocking all traffic
    Table 1 Blocking all traffic
    Example Value
    Direction
    Inbound
    Direction of the protected traffic.
    Source
    Any
    Origin of network traffic.
    Destination
    Any
    Receiver of network traffic.
    Service
    Any
    Protocol, source port, and destination port of network traffic.
    Application
    Any
    Protection policy for application layer protocols.
    Action
    Block
    Action taken when traffic passes through the firewall.
  • The other rule allows traffic from a specified IP address to pass through and has the highest priority. Configure the following parameters as suggested, and configure other parameters as needed.
    Figure 2 Allowing a specified IP address
    Table 2 Allowing a specified IP address
    Example Value
    Direction
    Inbound
    Source
    IP Address/IP address group/Countries and regions
    IP Address
    192.168.0.0
    Destination
    Any
    Service
    Any
    Application
    Any
    Action
    Allow
The following figure shows a rule that blocks all access traffic from Singapore. For details about parameter configuration, see Blocking or Allowing Traffic by Adding Protection Rules.
Figure 3 Intercepting the access traffic from Singapore
Table 3 Blocking access from a region
Example Value
Direction
Inbound
Source
Singapore
Select Countries and regions and specify a region.
Destination
Any
Service
Any
Application
Any
Action
Block
To allow an EIP (xx.xx.xx.48) to access cfw-test.com and *.example.com, configure parameters as follows. The parameters not mentioned below can be configured as needed. For details about parameter configuration, see Blocking or Allowing Traffic by Adding Protection Rules.
  • Create an application domain name group and configure the platform domain names. An example is as follows:
    Figure 4 Adding the domain name group of a platform
    Table 4 Adding the domain name group of a platform
    Example Value
    Domain Name Group Types
    Application
    Select a domain name group type.
    Group Name
    Platform_A
    Name of a user-defined domain name group.
    Domain names
    cfw-test.com
    *.example.com
    Enter a domain name or wildcard domain name. Use commas (,), line breaks, semicolons (;), or spaces to separate multiple domain names.
    Allow traffic from a service to a platform.
    Describe the content and application scenarios of the current domain name group.
  • Configure the following protection rules:
    • The following rule blocks all traffic and has the lowest priority.
      Figure 5 Blocking all traffic
      Table 5 Blocking all traffic
      Example Value
      Direction
      Outbound
      Source
      Any
      Destination
      Any
      Service
      Any
      Application
      Any
      Action
      Block
    • The other rule allows the traffic from the EIP to the platform. The priority is the highest. An example is as follows:
      Figure 6 Allowing the traffic from an EIP to a platform
      Table 6 Allowing the traffic from an EIP to a platform
      Example Value
      Direction
      Outbound
      Source
      IP Address
      xx.xx.xx.48
      Destination
      IP Address/IP address group/Countries and regions/Domain name/Domain name group
      Application, Application Domain Name Group, X_platform
      Domain Name/Domain Name Group
      Service
      Service. Retain the default values for other parameters.
      Application
      Application: HTTP and HTTPS
      Action
      Allow
The following uses SNAT as an example. If your private IP address is 10.1.1.2 and the external domain name accessible through the NAT gateway is www.example.com, you can configure NAT protection as follows. Configure other parameters as needed. For more information, see Blocking or Allowing Traffic Using Protection Rules.
Figure 7 Configuring a NAT protection rule
Table 7 Configuring a NAT protection rule
Example
Direction
SNAT
Source
IP Address
10.1.1.2
Destination
Network
www.example.com
Service
Service
TCP, 1-65535, 1-65535
Application
Application
HTTP, HTTPS
Protective Action
Allow
References
