Help Center/ Cloud Container Engine/ User Guide (ME-Abu Dhabi Region)/ FAQs/ Networking/ Network Planning/ How Can I Configure a Security Group Rule for a Cluster?
CCE is a universal container platform. Its default security group rules apply to common scenarios. When a cluster is created, a security group is automatically created for the master nodes and worker nodes, separately. The name of the master node security group is in the format of {Cluster name}-cce-control-{Random ID}, and that of the worker node security group is in the format of {Cluster name}-cce-node-{Random ID}. For a CCE Turbo cluster, an additional ENI security group, with the name following the format of {Cluster name}-cce-eni-{Random ID}, will be created.
To modify the security group rules, log in to the management console and choose Service List > Networking > Virtual Private Cloud. On the page displayed, choose Access Control > Security Groups in the navigation pane, locate the rpw containing the target security group, and modify the rules.
You can check the default security group rules of clusters using different network models in:
  • Be careful when modifying or removing security group rules as it could impact the cluster's operation. Avoid modifying the rules for the ports essential to CCE.
  • When adding a security group rule, ensure that this rule does not conflict with the existing rules. If there is a conflict, existing rules may become invalid, affecting cluster running.
Security Group Rules in a Cluster That Uses the VPC Network Model
Worker node security group
A security group, with a name following the format of {Cluster name}-cce-node-{Random ID}, is automatically created for the worker nodes in a cluster. For details about the default ports, see Table 1.
Table 1 Default ports in the security group of the worker nodes in a cluster that uses the VPC network model
Direction
Port
Default Source Address
Modification Suggestion
Impact After Modification
Inbound rules
All UDP ports
VPC CIDR block
Allow access between the worker nodes and between the worker nodes and the master nodes.
Modification not recommended
If the configuration is modified, the cluster will not function correctly.
All TCP ports
All ICMP ports
Master node security group
Allow the master nodes to access the worker nodes.
TCP port range: 30000 to 32767
All IP addresses (0.0.0.0/0)
Allow access from the NodePort Services.
Modification made if necessary
The ports must allow traffic from the CIDR blocks of the VPC, container, and load balancer.
UDP port range: 30000 to 32767
All
Container CIDR block
Allow containers within the cluster to access the nodes.
All
Restrict access from outside the worker node security group, but the access between pods in the worker node security group.
TCP port 22
Allow SSH access to Linux ECSs.
Modification recommended
You are advised to allow access only from fixed IP addresses or IP address ranges.
Outbound rule
All
Allow traffic on all ports by default. You are advised to retain this setting.
If you want to harden security by allowing traffic only on specific ports, remember to allow such ports. For details, see Hardening Outbound Rules.
A security group, with a name following the format of {Cluster name}-cce-control-{Random ID}, is automatically created for the master nodes in a cluster. For details about the default ports, see Table 2.
Table 2 Default ports in the security group of the master nodes in a cluster that uses the VPC network model
Direction
Port
Inbound rules
TCP port 5444
VPC CIDR block
Allow access from kube-apiserver, which provides lifecycle management for Kubernetes resources.
TCP port 5444
TCP port 9443
VPC CIDR block
Allow the network add-on of the worker nodes to access the master nodes.
TCP port 5443
Allow kube-apiserver of the master nodes to listen to the worker nodes.
The port must allow traffic from the CIDR blocks of the VPC, the control plane of the hosted service mesh, and container.
TCP port 8445
VPC CIDR block
Allow the storage add-on of the worker nodes to access the master nodes.
All
Restrict access from outside the master node security group, but the access between pods in the master node security group.
Outbound rule
All
Security Group Rules in a Cluster That Uses the Tunnel Network Model
A security group, with a name following the format of {Cluster name}-cce-node-{Random ID}, is automatically created for the worker nodes in a cluster. For details about the default ports, see Table 3.
Table 3 Default ports in the security group of the worker nodes in a cluster that uses the tunnel network model
Direction
Port
Inbound rules
UDP port 4789
Allow access between containers.
TCP port 10250
Master node CIDR block
Allow the master nodes to access kubelet on the worker nodes to run commands, for example, kubectl exec {pod}.
The ports must allow traffic from the CIDR blocks of the VPC, load balancer, and container.
TCP port 22
All
Outbound rule
All
A security group, with a name following the format of {Cluster name}-cce-control-{Random ID}, is automatically created for the master nodes in a cluster. For details about the default ports, see Table 4.
Table 4 Default ports in the security group of the master nodes in a cluster that uses the tunnel network model
Direction
Port
Inbound rules
UDP port 4789
TCP port 5444
VPC CIDR block
TCP port 5444
TCP port 9443
VPC CIDR block
TCP port 5443
TCP port 8445
VPC CIDR block
All
Outbound rule
All
Security Group Rules in a CCE Turbo Cluster That Uses the Cloud Native 2.0 Network Model
A security group, with a name following the format of {Cluster name}-cce-node-{Random ID}, is automatically created for the worker nodes in a cluster. For details about the default ports, see Table 5.
Table 5 Default ports in the security group of the worker nodes in a CCE Turbo cluster that uses the Cloud Native 2.0 network model
Direction
Port
Inbound rules
TCP port 10250
TCP port 22
All
All
Container subnet CIDR block
Outbound rule
All
A security group, with a name following the format of {Cluster name}-cce-control-{Random ID}, is automatically created for the master nodes in a cluster. For details about the default ports, see Table 6.
Table 6 Default ports in the security group of the master nodes in a CCE Turbo cluster that uses the Cloud Native 2.0 network model
Direction
Port
Inbound rules
TCP port 5444
TCP port 5444
VPC CIDR block
TCP port 9443
VPC CIDR block
TCP port 5443
TCP port 8445
VPC CIDR block
All
All
Allow traffic from all source IP addresses in the container subnet CIDR block.
Outbound rule
All
ENI security group
In a CCE Turbo cluster, an additional security group, with the name following the format of {Cluster name}-cce-eni-{Random ID}, is created. By default, containers in the cluster are bound to this security group. For details about the default ports, see Table 7.
Table 7 Default ports of the ENI security group in a CCE Turbo cluster that uses the Cloud Native 2.0 network model
Direction
Port
Inbound rules
All
ENI security group
Allow containers within the cluster to access each other.
VPC CIDR block
Allow instances in the cluster VPC to access the containers.
Outbound rule
All
By default, all security groups created by CCE allow all the outbound traffic. You are advised to retain this configuration. To harden outbound rules, ensure that the traffic on the ports listed in the following table is allowed.
Table 8 Minimum configurations of outbound security group rules for the worker nodes
Port
Allowed CIDR
UDP port 53
DNS server of the subnet
Allow traffic on the port for domain name resolution.
UDP port 5353
Allow traffic on the port for CoreDNS domain name resolution.
UDP port 4789 (required only by clusters that use the tunnel networks)
All IP addresses
TCP port 5443
TCP port 5444
CIDR blocks of the VPC and containers
TCP port 6443
None
TCP port 8445
VPC CIDR block
TCP port 9443
VPC CIDR block
All ports
198.19.128.0/17
Allow access to VPC Endpoint (VPCEP).
UDP port 123
100.125.0.0/16
Allow the worker nodes to access the internal NTP server.
TCP port 443
100.125.0.0/16
Allow the worker nodes to access OBS over internal networks to pull the installation package.
TCP port 6443
100.125.0.0/16
Allow the worker nodes to report that the worker nodes have been installed.
