Help Center/ Cloud Container Engine/ User Guide (ME-Abu Dhabi Region)/ Best Practices/ Security/ Configuration Suggestions on CCE Workload Identity Security
A workload identity enables workloads within a cluster to act as IAM users, granting them access to cloud services without the need for an IAM account's AK and SK. This helps to minimize security risks.
This section describes how to use workload identities in CCE.
Notes and Constraints
The cluster version must be v1.19.16 or later.
  1. Obtain the public key of the cluster serviceAccountToken from CCE. For details, see Step 1: Obtain the Public Key for Signature of the CCE Cluster.
  2. Create an identity provider on IAM. For details, see Step 2: Configure an Identity Provider.
  3. Obtain an IAM token from the workload and simulate an IAM user to access a cloud service. For details, see Step 3: Use a Workload Identity.
    The procedure is as follows:
    1. Deploy the application pod and obtain the OpenID Connect ID token file by mounting the identity provider.
    2. Use the mounted OpenID Connect ID token file in programs in the pod to access IAM and obtain a temporary IAM token.
    3. Access the cloud service using the IAM token in programs in the pod.
    Figure 1 Workflow
  1. Use kubectl to access the target cluster.
  2. Obtain the public key:
    kubectl get --raw /openid/v1/jwks
    The returned result is the public key of the cluster. The following is an example of the command output:
    # kubectl get --raw /openid/v1/jwks
    {"keys":[{"use":"sig","kty":"RSA","kid":"*****","alg":"RS256","n":"*****","e":"AQAB"}]}
  1. Log in to the IAM console, choose Identity Providers in the navigation pane, and click Create Identity Provider in the upper right corner. On the displayed page, set Protocol to OpenID Connect and SSO Type to Virtual user and click OK.
  2. In the identity provider list, locate the row containing the new identity provider and click Modify in the Operation column to modify the identity provider information.
    Access Type: Select Programmatic access.
    Configuration Information
    • Identity Provider URL: Enter https://kubernetes.default.svc.cluster.local.
    • Client ID: Enter an ID, which will be used when you create a container.
      You are not advised to use a client ID consisting solely of digits. If the client ID consists only of digits, enclose it in double quotation marks ("") when editing the YAML file for the workload. If the client ID is 123456789, it should be entered as "123456789" in the YAML file.
    • Signing Key: Enter the JWKS of the CCE cluster obtained in Step 1: Obtain the Public Key for Signature of the CCE Cluster.
    Identity Conversion Rules
    An identity conversion rule maps the ServiceAccount of a workload to an IAM user.
    For example, create a ServiceAccount named oidc-token in namespace default of the cluster and map it to user group demo. If you use the identity provider ID to access cloud services, you have the permissions of the demo user group. The attribute must be sub. The value is in the format of system:serviceaccount:Namespace:ServiceAccountName.
    Rules are in the JSON format as follows:
            "local": [
                    "user": {
                        "name": "test"
                    "group": {
                        "name": "demo"
            "remote": [
                    "type": "sub",
                    "any_one_of": [
                        "system:serviceaccount:default:oidc-token"
  3. Click OK.
  1. Create a ServiceAccount, whose name must be the value of ServiceAccountName set in Step 2: Configure an Identity Provider.
    apiVersion: v1
    kind: ServiceAccount
  2. Mount the identity provider to the workload and obtain the OpenID Connect ID token file.
    An example is as follows:
    apiVersion: apps/v1
    kind: Deployment
      replicas: 1
      selector:
        matchLabels:
          app: nginx
          version: v1
      template:
          labels:
            app: nginx
            version: v1
          containers:
          - name: container-1
            image: nginx:latest
            volumeMounts:
            - mountPath: "/var/run/secrets/tokens"     # Mount the serviceAccountToken generated by Kubernetes to the /var/run/secrets/tokens/oidc-token file.
          imagePullSecrets:
          - name: default-secret
          serviceAccountName: oidc-token      # Name of the created ServiceAccount
          volumes:
          - name: oidc-token
            projected:
              defaultMode: 420
              sources:
              - serviceAccountToken:
                  audience: client_id   # Must be the client ID of the identity provider.
                  expirationSeconds: 7200       # Expiry period
                  path: oidc-token              # Path name, which can be customized
  3. After the creation is complete, log in to the container. The content of the /var/run/secrets/tokens/oidc-token file is the serviceAccountToken generated by Kubernetes.
    If the serviceAccountToken is used for more than 24 hours or 80% of its expiry period, kubelet will automatically rotate the serviceAccountToken.
  4. Use the OpenID Connect ID token to call the API for . The X-Subject-Token field in the response header is the IAM token. Then, you can use this token to access cloud services.
    The following shows an example:
    curl -i --location --request POST 'https://{{iam endpoint}}/v3.0/OS-AUTH/id-token/tokens' \
     --header 'X-Idp-Id: workload_identity' \
     --header 'Content-Type: application/json' \
     --data @token_body.json
    Specifically:
    • {{iam endpoint}} indicates the endpoint of IAM.
    • workload_identity is the identity provider name, which is the same as that configured in Step 2: Configure an Identity Provider.
    • token_body.json is a local file and its content is as follows:
         "auth" : {
           "id_token" : {
             "id" : "eyJhbGciOiJSU..."
           "scope": {
             "project" : {
               "id" : "46419baef4324...",
               "name" : ******
      • $.auth.id_token.id: The value is the content of the /var/run/secrets/tokens/oidc-token file in the container.
      • $.auth.scope.project.id: indicates the project ID.
      • $.auth.scope.project.name: indicates the project name.
