Halaman ini belum tersedia dalam bahasa lokal Anda. Kami berusaha keras untuk menambahkan lebih banyak versi bahasa. Terima kasih atas dukungan Anda.
On this page
Help Center/ Cloud Container Engine/ User Guide (ME-Abu Dhabi Region)/ Best Practices/ Container/ Modifying Kernel Parameters Using a Privileged Container
Updated on 2024-01-04 GMT+08:00
To access a Kubernetes cluster from a client, you can use the Kubernetes command line tool kubectl.
  1. Create a DaemonSet in the background, select the Nginx image, enable the Privileged Container, configure the lifecycle, and add the hostNetwork field (value: true).
    1. Create a daemonSet file.
      vi daemonSet.yaml
      An example YAML file is provided as follows:
      NOTICE:
      The spec.spec.containers.lifecycle field indicates the command that will be run after the container is started.
      kind: DaemonSet
      apiVersion: apps/v1
        labels:
        selector:
          matchLabels:
        template:
            labels:
            hostNetwork: true
            containers:
            - name: daemonset-test
              image: nginx:alpine-perl
              command:
              - "/bin/sh"
              args:
              - "-c"
              - while :; do  time=$(date);done
              imagePullPolicy: IfNotPresent
              lifecycle:
                postStart:
                  exec:
                    command:
                    - sysctl
                    - "-w"
                    - net.ipv4.tcp_tw_reuse=1
              securityContext:
                privileged: true
            imagePullSecrets:
            - name: default-secret
    2. Create a DaemonSet.
      kubectl create –f daemonSet.yaml
  2. Check whether the DaemonSet is successfully created.
    kubectl get daemonset DaemonSet name
    In this example, run the following command:
    kubectl get daemonset daemonset-test
    Information similar to the following is displayed:
    NAME               DESIRED    CURRENT   READY    UP-T0-DATE    AVAILABLE     NODE SELECTOR   AGE
    daemonset-test     2          2         2        2             2             <node>          2h
  3. Query the container ID of DaemonSet on the node.
    docker ps -a|grep DaemonSet name
    docker ps -a|grep daemonset-test
    897b99faa9ce        3e094d5696c1                           "/bin/sh  -c while..."     31 minutes ago     Up  30 minutes  ault_fa7cc313-4ac1-11e9-a716-fa163e0aalba_0
  4. Access the container.
    docker exec -it containerid /bin/sh
    docker exec -it 897b99faa9ce /bin/sh
  5. Check whether the configured command is executed after the container is started.
    sysctl -a |grep net.ipv4.tcp_tw_reuse
    If the following information is displayed, the system parameters are modified successfully:
Kami menggunakan cookie untuk meningkatkan kualitas situs kami dan pengalaman Anda. Dengan melanjutkan penelusuran di situs kami berarti Anda menerima kebijakan cookie kami. Cari tahu selengkapnya
