Configuring a Custom Header Forwarding Policy for a LoadBalancer Ingress
Dedicated load balancer ingresses support custom header forwarding policies. You can configure different header key-value pairs to determine the backend Service to which data is forwarded.
- A CCE standard or Turbo cluster is available, and the cluster version meets the following requirements:
- v1.23: v1.23.16-r0 or later
- v1.25: v1.25.11-r0 or later
- v1.27: v1.27.8-r0 or later
- v1.28: v1.28.6-r0 or later
- v1.29: v1.29.2-r0 or later
- Other clusters of later versions
- The cluster can be accessed using kubectl. For details, see Accessing a Cluster Using kubectl.
Notes and Constraints
- This feature is only available when dedicated load balancers are used.
Using kubectl
- Use kubectl to access the cluster. For details, see Accessing a Cluster Using kubectl.
- Create a YAML file named ingress-test.yaml. The file name can be customized.
vi ingress-test.yaml
An example YAML file of an ingress created using an existing load balancer is as follows:apiVersion: networking.k8s.io/v1 kind: Ingress metadata: name: ingress-test namespace: default annotations: kubernetes.io/elb.port: '80' kubernetes.io/elb.id: 08eab934-1636-4d90-a4cd-cb3fa4330411 kubernetes.io/elb.class: performance # A dedicated load balancer is required. # Path /a can be accessed only through Header key1=value1 or key1=value2. The accessed Service is svc-a:80. kubernetes.io/elb.headers.svc-a: | { "key": "key1", "values": [ "value1", "value2" ] } # Path /b can be accessed only through Header key2=value1 or key2=value2. The accessed Service is svc-b:81. kubernetes.io/elb.headers.svc-b: | { "key": "key2", "values": [ "value1", "value2" ] } spec: rules: - host: '' http: paths: - path: /a backend: service: name: svc-a port: number: 80 property: ingress.beta.kubernetes.io/url-match-mode: STARTS_WITH pathType: ImplementationSpecific - path: /b backend: service: name: svc-b port: number: 81 property: ingress.beta.kubernetes.io/url-match-mode: STARTS_WITH pathType: ImplementationSpecific ingressClassName: cce
Table 1 Annotations for configuring a custom header forwarding policy Parameter
Type
kubernetes.io/elb.headers.${svc_name}
String
Custom header of the Service associated with an ingress. ${svc_name} is the Service name.
Format: a JSON string, for example, {"key": "test", "values": ["value1", "value2"]}
- key/value indicates the key-value pair of the custom header. A maximum of eight values can be configured.
Enter 1 to 40 characters for a key. Only letters, digits, hyphens (-), and underscores (_) are allowed.
Enter 1 to 128 characters for a value. Asterisks (*) and question marks (?) are allowed, but spaces and double quotation marks are not allowed. An asterisk can match zero or more characters, and a question mark can match one character.
- After a custom header forwarding policy is configured for an ingress, a grayscale release policy cannot be created for the ingress.
- Enter 1 to 51 characters for ${svc_name}.
- Create an ingress.
If information similar to the following is displayed, the ingress has been created:
ingress/ingress-test created
- Check the created ingress.
kubectl get ingress
NAME CLASS HOSTS ADDRESS PORTS AGE ingress-test cce * 121.**.**.** 80 10s
