Using DSS Through a Static PV
CCE allows you to create a PV using an existing DSS disk. After the PV is created, you can create a PVC and bind it to the PV. This mode applies to scenarios where underlying storage is available.
- You have created a cluster of v1.21.15-r0, v1.23.14-r0, v1.25.9-r0, v1.27.6-r0, v1.28.4-r0, v1.29.1-r0, or later, and CCE Container Storage (Everest) of v2.4.5 or later has been installed in the cluster.
- To create a cluster using commands, ensure kubectl is used. For details, see Accessing a Cluster Using kubectl.
- You have created a DSS disk that meets the following requirements:
- The DSS disk cannot be a system disk or shared disk.
- The DSS disk must be of the SCSI type (the default disk type is VBD when you create a DSS disk).
- The DSS disk must be available and not used by other resources.
- If the DSS disk is encrypted, the key must be available.
- The DSS disk must be in the default enterprise project or the enterprise project to which the cluster belongs.
Notes and Constraints
- DSS disks cannot be attached across AZs and cannot be used by multiple workloads, multiple pods of the same workload, or multiple tasks. Data sharing of a shared disk is not supported between nodes in a CCE cluster. If a DSS disk is attached to multiple nodes, I/O conflicts and data cache conflicts may occur. Therefore, select only one pod when creating a Deployment that uses DSS.
- If an HPA policy is used to expand the capacity of a workload with a DSS disk attached, new pods cannot be started because the DSS disk cannot attach to them.
Using an Existing DSS Disk on the Console
- Statically create a PVC and PV.
- Choose Storage in the navigation pane. In the right pane, click the PVCs tab. Click Create PVC in the upper right corner. In the dialog box displayed, configure PVC parameters.
PVC Type
In this example, select DSS.
PVC Name
Enter the PVC name, which must be unique in a namespace.
Creation Method
- If underlying storage is available, create a PV or use an existing PV to statically create a PVC.
- If no underlying storage is available, select Dynamically provision. For details, see Using DSS Through a Dynamic PV.
In this example, select Create new to create both a PV and PVC on the console.
PVa
Select an existing PV in the cluster. For details about how to create a PV, see "Creating a storage volume" in Related Operations.
You do not need to specify this parameter in this example.
DSSb
Click Select DSS. On the displayed page, select the DSS volume that meets your requirements and click OK.
PV Nameb
Enter the PV name, which must be unique in the same cluster.
Access Modeb
DSS volumes support only ReadWriteOnce, indicating that a storage volume can be mounted to one node in read/write mode.
Reclaim Policyb
You can select Delete or Retain to specify the reclaim policy of the underlying storage when the PVC is deleted.
a: The parameter is available when Creation Method is set to Use existing.
b: The parameter is available when Creation Method is set to Create new.
- Click Create to create a PVC and a PV.
You can choose Storage in the navigation pane and view the created PVC and PV on the PVCs and PVs tab pages, respectively.
- Create an application.
- Choose Workloads in the navigation pane. In the right pane, click the StatefulSets tab.
- Click Create Workload in the upper right corner. On the displayed page, click Data Storage in the Container Information area under Container Settings and choose Add Volume > PVC.
Mount and use storage volumes, as shown in Table 1. For details about other parameters, see Workloads.
Table 1 Mounting a storage volume Parameter
PVC
Select an existing DSS volume.
A DSS volume can be mounted to only one workload.
Mount Path
Enter a mount path, for example, /tmp.
This parameter specifies a container path to which a data volume will be mounted. Do not mount the volume to a system directory such as / or /var/run. This may lead to container errors. Mount the volume to an empty directory. If the directory is not empty, ensure that there are no files that affect container startup. Otherwise, the files will be replaced, leading to container startup failures or workload creation failures.NOTICE:If a volume is mounted to a high-risk directory, use an account with minimum permissions to start the container. Otherwise, high-risk files on the host may be damaged.
Subpath
Enter the subpath of the storage volume and mount a path in the storage volume to the container. In this way, different folders of the same storage volume can be used in a single pod. tmp, for example, indicates that data in the mount path of the container is stored in the tmp folder of the storage volume. If this parameter is left blank, the root path will be used by default.
Permission
- Read-only: You can only read the data in the mounted volumes.
- Read-write: You can modify the data volumes mounted to the path. Newly written data will not be migrated if the container is migrated, which may cause data loss.
In this example, the disk is mounted to the /data path of the container. The container data generated in this path is stored in the DSS disk.
A non-shared DSS disk can be attached to only one workload pod. If there are multiple pods, extra pods cannot start properly. Ensure that the number of workload pods is 1 if a DSS disk is attached.
If multiple workload pods are needed, create a StatefulSet and dynamically mount a PV to each pod. For details, see Dynamically Mounting a DSS Disk to a StatefulSet.
- After the configuration, click Create Workload.
After the workload is created, the data in the container mount directory will be persistently stored. Verify the storage by referring to Verifying Data Persistence.
Using an Existing DSS Disk Through kubectl
- Use kubectl to access the cluster.
- Create a PV. If a PV has been created in your cluster, skip this step.
- Create the pv-dss.yaml file.
apiVersion: v1 kind: PersistentVolume metadata: annotations: pv.kubernetes.io/provisioned-by: everest-csi-provisioner everest.io/reclaim-policy: retain-volume-only # (Optional) The underlying volume is retained when the PV is deleted. name: pv-dss # PV name labels: failure-domain.beta.kubernetes.io/region: <your_region> # Region of the node where the application is to be deployed failure-domain.beta.kubernetes.io/zone: <your_zone> # AZ of the node where the application is to be deployed spec: accessModes: - ReadWriteOnce # Access mode, which must be ReadWriteOnce for DSS capacity: storage: 10Gi # Disk capacity, in the unit of GiB. The value ranges from 1 to 32768. csi: driver: disk.csi.everest.io # Dependent storage driver for the mounting fsType: ext4 # Must be the same as that of the original file system of the disk. volumeAttributes: everest.io/disk-mode: SCSI # Device type of the DSS disk. Only SCSI is supported. everest.io/disk-volume-type: SAS # Disk type everest.io/csi.dedicated-storage-id: <dss_id> # ID of the DSS storage pool storage.kubernetes.io/csiProvisionerIdentity: everest-csi-provisioner everest.io/crypt-key-id: <your_key_id> # (Optional) Encryption key ID. Mandatory for an encrypted disk. everest.io/enterprise-project-id: <your_project_id> # (Optional) Enterprise project ID. If an enterprise project is specified, use the same enterprise project when creating a PVC. Otherwise, the PVC cannot be bound to a PV. persistentVolumeReclaimPolicy: Delete # Reclaim policy storageClassName: csi-disk-dss # Storage class name of the DSS disk
Table 2 Key parameters Parameter
Mandatory
No
This parameter is optional and can only be set to retain-volume-only.
This parameter is valid only when the Everest version is 1.2.9 or later and the reclaim policy is Delete. If the reclaim policy is Delete and the current value is retain-volume-only, the associated PV is deleted while the underlying storage volume is retained, when a PVC is deleted.
Yes
Region where the cluster is located.
For details about its value, see Regions and Endpoints.
Yes
AZ where the DSS volume is created. It must be the same as the AZ planned for the workload.
fsType
Yes
File system type, which defaults to ext4.
Yes
Disk type. All letters are in uppercase.- SAS: high I/O
- SSD: ultra-high I/O
Yes
ID of the DSS storage pool where the DSS disk resides.
To obtain a DSS storage pool ID, log in to the Cloud Server Console. In the navigation pane, choose Dedicated Distributed Storage Service > Storage Pools and click the name of the target storage pool. On the resource pool details page, copy the pool ID.
No
Mandatory when the disk is encrypted. Enter the encryption key ID selected during disk creation.
To obtain an encryption key ID, log in to the Cloud Server Console. In the navigation pane, choose Dedicated Distributed Storage Service > Disks. Click the name of the target disk to go to its details page. On the Summary tab page, copy the value of KMS Key ID in the Configuration Information area.
No
Optional.
Enterprise project ID of DSS. If an enterprise project is specified, use the same enterprise project when creating a PVC. Otherwise, the PVC cannot be bound to a PV.
To obtain an enterprise project ID, log in to the Cloud Server Console. In the navigation pane, choose Dedicated Distributed Storage Service > Disks. Click the name of the target disk to go to its details page. On the Summary tab page, click the enterprise project in Management Information to access the enterprise project console. Copy the corresponding ID to obtain the ID of the enterprise project to which the DSS disk belongs.
Yes
The Delete and Retain reclaim policies are supported. If high data security is required, select Retain to prevent data from being deleted by mistake.
Delete:
- If everest.io/reclaim-policy is not specified, both the PV and DSS disk will be deleted when a PVC is deleted.
- If everest.io/reclaim-policy is set to retain-volume-only, when a PVC is deleted, the PV will be deleted but the DSS disk will be retained.
Retain: When a PVC is deleted, both the PV and underlying storage resources will be retained. You need to manually delete these resources. After the PVC is deleted, the PV is in the Released state and cannot be bound to a PVC again.
storageClassName
Yes
The StorageClass for DSS disks is csi-disk-dss.
- Run the following command to create a PV:
kubectl apply -f pv-dss.yaml
- Create a PVC.
- Create the pvc-dss.yaml file.
apiVersion: v1 kind: PersistentVolumeClaim metadata: name: pvc-dss namespace: default annotations: everest.io/disk-volume-type: SAS # Disk type everest.io/csi.dedicated-storage-id: <dss_id> # ID of the DSS storage pool everest.io/crypt-key-id: <your_key_id> # (Optional) Encryption key ID. Mandatory for an encrypted disk. everest.io/enterprise-project-id: <your_project_id> # (Optional) Enterprise project ID. If you specify an enterprise project when creating a PV, ensure the same enterprise project is used when creating a PVC. Otherwise, the PVC will not bind to the PV. labels: failure-domain.beta.kubernetes.io/region: <your_region> # Region of the node where the application is to be deployed failure-domain.beta.kubernetes.io/zone: <your_zone> # AZ of the node where the application is to be deployed spec: accessModes: - ReadWriteOnce # The value must be ReadWriteOnce for DSS. resources: requests: storage: 10Gi # Disk capacity, ranging from 1 to 32768. The value must be the same as the storage size of the existing PV. storageClassName: csi-disk-dss # The StorageClass is DSS. volumeName: pv-dss # PV name
Table 3 Key parameters Parameter
Mandatory
Yes
Yes
AZ where the disk is created. It must be the same as the AZ planned for the workload.
Yes
storage
Yes
Requested capacity in the PVC, in Gi.
volumeName
Yes
PV name, which must be the same as the PV name in 1.
storageClassName
Yes
StorageClass name, which must be the same as the StorageClass of the PV in 1.
- Run the following command to create a PVC:
kubectl apply -f pvc-dss.yaml
- Create a file named web-dss.yaml. In this example, the disk is mounted to the /data path.
apiVersion: apps/v1 kind: StatefulSet metadata: name: web-dss namespace: default spec: replicas: 1 selector: matchLabels: app: web-dss serviceName: web-dss # Headless Service name template: metadata: labels: app: web-dss spec: containers: - name: container-1 image: nginx:latest volumeMounts: - name: pvc-disk-dss # Volume name, which must be the same as the volume name in the volumes field mountPath: /data # Location where the storage volume is mounted imagePullSecrets: - name: default-secret volumes: - name: pvc-disk-dss # Volume name, which can be customized persistentVolumeClaim: claimName: pvc-dss # Name of the created PVC --- apiVersion: v1 kind: Service metadata: name: web-dss # Headless Service name namespace: default labels: app: web-dss spec: selector: app: web-dss clusterIP: None ports: - name: web-dss targetPort: 80 nodePort: 0 port: 80 protocol: TCP type: ClusterIP
- Run the following command to create a workload to which the DSS volume is mounted:
kubectl apply -f web-dss.yaml
- View the deployed application and DSS volume files.
- Run the following command to view the created pod:
kubectl get pod | grep web-dss
Expected output:web-dss-0 1/1 Running 0 38s
- Run the following command to check whether the DSS volume has been mounted to the /data path:
kubectl exec web-dss-0 -- df | grep data
Expected output:
/dev/sdc 10255636 36888 10202364 0% /data
- Run the following command to check the files in the /data path:
kubectl exec web-dss-0 -- ls /data
Expected output:
lost+found
- Run the following command to create a file named static in the /data path:
kubectl exec web-dss-0 -- touch /data/static
Expected output:
lost+found static
- Run the following command to delete the pod named web-dss-0:
kubectl delete pod web-dss-0
Expected output:
pod "web-dss-0" deleted
- After the deletion, the StatefulSet controller automatically creates a replica with the same name. Run the following command to check whether the files in the /data path have been modified:
Expected output:
lost+found static
The static file is retained, indicating that the data in the DSS volume can be stored persistently.
Related Operations
Operation |
Description |
Procedure |
Creating a storage volume (PV) |
Create a PV on the CCE console. |
Expanding the capacity of DSS storage |
Quickly expand the capacity of an attached DSS disk on the CCE console. |
Viewing events |
View event names, event types, number of occurrences, Kubernetes events, first occurrence time, and last occurrence time of the PVC or PV. |
Viewing a YAML file |
View, copy, or download the YAML file of a PVC or PV. |
