Expanding the Capacity of an EVS Disk
If the EVS disk attached to a workload does not have enough space, you can increase its capacity by expanding it. This section describes how to expand the capacity of an EVS disk through the console.
You have created a cluster and installed the CCE Container Storage (Everest) add-on in the cluster.
Pay-per-Use EVS Disk
  2. Choose Storage in the navigation pane and click the PersistentVolumeClaims (PVCs) tab. Click More in the Operation column of the target PVC and select Scale-out.
  3. Enter the capacity to be added and click OK.
    The disk size can only be increased, not decreased.
