Help Center/
Cloud Container Engine/
User Guide (ME-Abu Dhabi Region)/
Settings/
Heterogeneous Resources
GPU Settings
- Default Cluster Driver: specifies the default GPU driver version used by the GPU nodes in a cluster. To use a custom driver, enter the download link of the NVIDIA driver. For details, see Obtaining the Driver Link from Public Network.
- Node Pool Configurations: If you do not want all GPU nodes in a cluster to use the same driver, CCE allows you to install a different GPU driver for each node pool. After you customize a GPU driver for a node pool, nodes in the node pool will preferentially use the custom driver. Nodes for which no driver is specified will use the cluster's default driver.
- The system installs the driver of the version specified for the node pool. The driver applies only to new nodes in the node pool.
- After the driver version is updated, it takes effect on the nodes newly added to the node pool. Existing nodes must restart to apply the changes.
Parent topic: Settings
