Configuring HTTP/2 for a LoadBalancer Ingress
Ingresses can use HTTP/2 to expose Services. Connections from the load balancer to your application use HTTP/1.x by default. If your application is capable of receiving HTTP/2 requests, enable the use of HTTP/2 by referring to Using the CCE Console to Configure HTTP/2 or Using kubectl to Configure HTTP/2.
- A CCE standard or Turbo cluster is available, and the cluster version meets the following requirements:
- v1.23: v1.23.13-r0 or later
- v1.25: v1.25.8-r0 or later
- v1.27: v1.27.5-r0 or later
- v1.28: v1.28.3-r0 or later
- Other clusters of later versions
- An available workload has been deployed in the cluster for external access. If no workload is available, deploy a workload by referring to Creating a Deployment, Creating a StatefulSet, or Creating a DaemonSet.
- A Service for external access has been configured for the workload. Services Supported by LoadBalancer Ingresses lists the Service types supported by LoadBalancer ingresses.
- You can obtain a trusted certificate from a certificate provider.
Notes and Constraints
- Only an HTTPS-compliant load balancer supports HTTP/2.
- After HTTP/2 is configured, if you delete the advanced configuration for enabling HTTP/2 on the CCE console or delete the target annotation from the YAML file, HTTP/2 will be disabled on the ELB.
- Choose Services & Ingresses in the navigation pane, click the Ingresses tab, and click Create Ingress in the upper right corner.
- Configure ingress parameters.
This example explains only key parameters for configuring HTTP/2. You can configure other parameters as required. For details, see Creating a LoadBalancer Ingress on the Console.
Table 1 Key parameters Parameter
Example
Name
Enter an ingress name.
ingress-test
Load Balancer
Select a load balancer to be associated with the ingress or automatically create a load balancer.
Shared
Listener
- External Protocol: Select HTTPS.
- External Port: specifies the port of the load balancer listener. The default HTTPS port is 443.
- Certificate Source: Select ELB server certificate.
- Server Certificate: Use a certificate created on ELB.
If no certificate is available, go to the ELB console and create one.
- Advanced Options: Add advanced configurations, select HTTP2, and set its status to Enable.
- External Protocol: HTTPS
- External Port: 443
- Certificate Source: ELB server certificate
- Server Certificate: cert-test
- Advanced Options: HTTP2 enabled
Forwarding Policy
- Domain Name: Enter an actual domain name to be accessed. If it is left blank, the ingress can be accessed through the IP address. Ensure that the domain name has been registered and licensed. Once a forwarding policy is configured with a domain name specified, you must use the domain name for access.
- Path Matching Rule: Select Prefix match, Exact match, or RegEx match.
- Path: Enter the path provided by a backend application for external access. The path added must be valid in the backend application, or the forwarding cannot take effect.
- Destination Service: Select an existing Service. Only Services that meet the requirements are automatically displayed in the Service list.
- Destination Service Port: Select the access port of the destination Service.
- Domain Name: You do not need to configure this parameter.
- Path Matching Rule: Prefix match
- Path: /
- Destination Service: nginx
- Destination Service Port: 80
- Click OK.
- Use kubectl to access the cluster. For details, see Accessing a Cluster Using kubectl.
- Create a YAML file named ingress-test.yaml. The file name can be customized.
vi ingress-test.yaml
An example YAML file of an ingress associated with an existing load balancer is as follows:apiVersion: networking.k8s.io/v1 kind: Ingress metadata: name: ingress-test annotations: kubernetes.io/elb.id: <your_elb_id> # Replace it with the ID of your existing load balancer. kubernetes.io/elb.ip: <your_elb_ip> # Replace it with the IP of your existing load balancer. kubernetes.io/elb.port: '443' kubernetes.io/elb.http2-enable: 'true' # Enable HTTP/2. spec: tls: - secretName: ingress-test-secret rules: - host: '' http: paths: - path: '/' backend: service: name: <your_service_name> # Replace it with the name of your target Service. port: number: 80 # Replace 80 with the port number of your target Service. property: ingress.beta.kubernetes.io/url-match-mode: STARTS_WITH pathType: ImplementationSpecific ingressClassName: cce
Table 2 HTTP/2 parameters Parameter
Mandatory
Type
No
String
Whether HTTP/2 is enabled. Request forwarding using HTTP/2 improves the access performance between your application and the load balancer. However, the load balancer still uses HTTP/1.x to forward requests to the backend server.
Options:
- true: enabled
- false: disabled (default value)
Note: HTTP/2 can be enabled or disabled only when the listener uses HTTPS. This parameter is invalid and defaults to false when the listener protocol is HTTP.
- Create an ingress.
If information similar to the following is displayed, the ingress has been created:
ingress/ingress-test created
- Check the created ingress.
kubectl get ingress
NAME CLASS HOSTS ADDRESS PORTS AGE ingress-test cce * 121.**.**.** 80,443 10s
