Using an OBS Bucket Through a Dynamic PV
This section describes how to automatically create an OBS bucket. It is applicable when no underlying storage volume is available.
Notes and Constraints
  • If OBS volumes are used, the owner group and permission of the mount point cannot be modified.
  • Every time an OBS volume is mounted to a workload through a PVC, a resident process is created in the backend. When a workload uses too many OBS volumes or reads and writes a large number of object storage files, resident processes will consume a significant amount of memory. To ensure stable running of the workload, make sure that the number of OBS volumes used does not exceed the requested memory. For example, if the workload requests for 4 GiB of memory, the number of OBS volumes should be no more than 4.
  • Secure containers do not support OBS volumes.
  • Hard links are not supported when common buckets are mounted.
  • OBS allows a single user to create a maximum of 100 buckets. If a large number of dynamic PVCs are created, the number of buckets may exceed the upper limit, and no more OBS buckets can be created. In this case, use OBS by calling its API or SDK and do not mount OBS buckets to workloads.
Automatically Creating an OBS Volume on the Console
  2. Dynamically create a PVC and PV.
    1. Choose Storage in the navigation pane. In the right pane, click the PVCs tab. Click Create PVC in the upper right corner. In the dialog box displayed, configure PVC parameters.
      PVC Type
      In this example, select OBS.
      PVC Name
      Enter the PVC name, which must be unique in a namespace.
      Creation Method
      • If no underlying storage is available, select Dynamically provision to create a PVC, PV, and underlying storage on the console in cascading mode.
      • If underlying storage is available, create a PV or use an existing PV to statically create a PVC. For details, see Using an Existing OBS Bucket Through a Static PV.
      In this example, select Dynamically provision.
      Storage Classes
      The default StorageClass of OBS volumes is csi-obs.
      You can customize a StorageClass and configure its reclaim policy and binding mode. For details, see Creating a StorageClass Using the CCE Console.
      (Optional) Storage Volume Name Prefix
      Available only when the cluster version is v1.23.14-r0, v1.25.9-r0, v1.28.4-r0, or later, and Everest of v2.4.15 or later is installed in the cluster.
      This parameter specifies the name of the underlying storage that is automatically created. The actual underlying storage name is in the format of "Storage volume name prefix + PVC UID". If this parameter is left blank, the default prefix pvc will be used.
      For example, if the storage volume name prefix is set to test, the actual underlying storage name is test-{UID}.
      Instance Type
      • Parallel file system: a high-performance file system provided by OBS. It provides millisecond-level access latency, TB/s-level bandwidth, and million-level IOPS.
      • Object bucket: provides reliable, high-performance, secure, and budget-friendly storage for data. They have no restrictions on the quantity of files or storage capacity.
      OBS Class
      You can select the following object bucket types:
      • Standard: Applicable when a large number of hotspot files or small-sized files need to be accessed frequently (multiple times per month on average) and require fast access response.
      • Infrequent access: Applicable when data is not frequently accessed (fewer than 12 times per year on average) but requires fast access response.
      Access Mode
      OBS volumes support only ReadWriteMany, indicating that a storage volume can be mounted to multiple nodes in read/write mode. For details, see Volume Access Modes.
      Access Key (AK/SK)
      Custom (Recommended): Customize a secret if you want to assign different user permissions to different OBS storage devices. For details, see Using a Custom Access Key (AK/SK) to Mount an OBS Volume.
      Only secrets with the secret.kubernetes.io/used-by = csi label can be selected. The secret type is cfe/secure-opaque. If no secret is available, click Create Secret to create one.
      • Name: Enter a secret name.
      • Namespace: Select the namespace where the secret is.
      • Access Key (AK/SK): Upload a key file in .csv format. For details, see Obtaining an Access Key.
      Enterprise Project
      The default enterprise project, the enterprise project to which the cluster belongs, or the enterprise project specified by StorageClass is available.
    2. Click Create to create a PVC and a PV.
      You can choose Storage in the navigation pane and view the created PVC and PV on the PVCs and PVs tab pages, respectively.
  3. Create an application.
    1. Choose Workloads in the navigation pane. In the right pane, click the Deployments tab.
    2. Click Create Workload in the upper right corner. On the displayed page, click Data Storage in the Container Information area under Container Settings and choose Add Volume > PVC.
      Mount and use storage volumes, as shown in Table 1. For details about other parameters, see Workloads.
      Table 1 Mounting a storage volume
      PVC
      Select an existing OBS volume.
      Mount Path
      Enter a mount path, for example, /tmp.
      This parameter specifies a container path to which a data volume will be mounted. Do not mount the volume to a system directory such as / or /var/run. This may lead to container errors. Mount the volume to an empty directory. If the directory is not empty, ensure that there are no files that affect container startup. Otherwise, the files will be replaced, leading to container startup failures or workload creation failures.
      NOTICE:
      If a volume is mounted to a high-risk directory, use an account with minimum permissions to start the container. Otherwise, high-risk files on the host may be damaged.
      Subpath
      Enter the subpath of the storage volume and mount a path in the storage volume to the container. In this way, different folders of the same storage volume can be used in a single pod. tmp, for example, indicates that data in the mount path of the container is stored in the tmp folder of the storage volume. If this parameter is left blank, the root path will be used by default.
      Permission
      • Read-only: You can only read the data in the mounted volumes.
      • Read-write: You can modify the data volumes mounted to the path. Newly written data will not be migrated if the container is migrated, which may cause data loss.
      In this example, the disk is mounted to the /data path of the container. The container data generated in this path is stored in the OBS volume.
    3. After the configuration, click Create Workload.
      After the workload is created, the data in the container mount directory will be persistently stored. Verify the storage by referring to Verifying Data Persistence and Sharing.
Automatically Creating an OBS Volume Through kubectl
  1. Use kubectl to access the cluster.
  2. Use StorageClass to dynamically create a PVC and PV.
    1. Create the pvc-obs-auto.yaml file.
      apiVersion: v1
      kind: PersistentVolumeClaim
        namespace: default
        annotations:
          everest.io/obs-volume-type: STANDARD    # OBS
          csi.storage.k8s.io/fstype: obsfs        # Instance type
          csi.storage.k8s.io/node-publish-secret-name: <your_secret_name>       # Custom secret name
          csi.storage.k8s.io/node-publish-secret-namespace: <your_namespace>    # Namespace of the custom secret
          everest.io/enterprise-project-id: <your_project_id>     # (Optional) Enterprise project ID
          everest.io/csi.volume-name-prefix: test  # (Optional) Storage volume name prefix of the automatically created underlying storage
        accessModes:
          - ReadWriteMany             # The value must be ReadWriteMany for OBS.
        resources:
          requests:
            storage: 1Gi               # OBS volume capacity
        storageClassName: csi-obs    # The StorageClass is OBS.
      Table 2 Key parameters
      Mandatory
      Yes
      OBS StorageClass.
      • If fsType is set to s3fs, standard buckets (STANDARD) and infrequent access buckets (WARM) are supported.
      • This parameter is invalid when fsType is set to obsfs.
      Yes
      Instance type. The value can be obsfs or s3fs.
      • obsfs: a parallel file system
      • s3fs: object bucket
      No
      Custom secret name.
      (Recommended) Select this option if you want to assign different user permissions to different OBS storage devices. For details, see Using a Custom Access Key (AK/SK) to Mount an OBS Volume.
      No
      Namespace of a custom secret.
      No
      Enterprise project ID of OBS.
      To obtain an enterprise project ID, log in to the EPS console, click the name of the target enterprise project, and copy the enterprise project ID.
      No
      (Optional) This parameter is available only when the cluster version is v1.23.14-r0, v1.25.9-r0, v1.27.6-r0, v1.28.4-r0, or later, and Everest of v2.4.15 or later is installed in the cluster.
      Enter 1 to 26 characters that cannot start or end with a hyphen (-). Only lowercase letters, digits, and hyphens (-) are allowed.
      storage
      Yes
      Requested capacity in the PVC, in Gi.
      For OBS, this field is used only for verification (cannot be empty or 0). Its value is fixed at 1, and any value you set does not take effect for OBS.
      storageClassName
      Yes
      StorageClass name, which is csi-obs for an OBS volume.
    2. Run the following command to create a PVC:
      kubectl apply -f pvc-obs-auto.yaml
    1. Create a file named web-demo.yaml. In this example, the OBS volume is mounted to the /data path.
      apiVersion: apps/v1
      kind: Deployment
        namespace: default
        replicas: 2
        selector:
          matchLabels:
            app: web-demo
        template:
            labels:
              app: web-demo
            containers:
            - name: container-1
              image: nginx:latest
              volumeMounts:
              - name: pvc-obs-volume    # Volume name, which must be the same as the volume name in the volumes field
                mountPath: /data  # Location where the storage volume is mounted
            imagePullSecrets:
              - name: default-secret
            volumes:
              - name: pvc-obs-volume    # Volume name, which can be customized
                persistentVolumeClaim:
                  claimName: pvc-obs-auto    # Name of the created PVC
    2. Run the following command to create a workload to which the OBS volume is mounted:
      kubectl apply -f web-demo.yaml
      After the workload is created, you can try Verifying Data Persistence and Sharing.
  1. View the deployed application and files.
    1. Run the following command to view the created pod:
      kubectl get pod | grep web-demo
      Expected output:
      web-demo-846b489584-mjhm9   1/1     Running   0             46s
      web-demo-846b489584-wvv5s   1/1     Running   0             46s
    2. Run the following commands in sequence to view the files in the /data path of the pods:
      kubectl exec web-demo-846b489584-mjhm9 -- ls /data
      kubectl exec web-demo-846b489584-wvv5s -- ls /data
      If no result is returned for both pods, no file exists in the /data path.
  2. Run the following command to create a file named static in the /data path:
    kubectl exec web-demo-846b489584-mjhm9 --  touch /data/static
  3. Run the following command to check the files in the /data path:
    Expected output:
    static
  4. Verify data persistence.
    1. Run the following command to delete the pod named web-demo-846b489584-mjhm9:
      kubectl delete pod web-demo-846b489584-mjhm9
      Expected output:
      pod "web-demo-846b489584-mjhm9" deleted
      After the deletion, the Deployment controller automatically creates a replica.
    2. Run the following command to view the created pod:
      The expected output is as follows, in which web-demo-846b489584-d4d4j is the newly created pod:
      web-demo-846b489584-d4d4j   1/1     Running   0             110s
      web-demo-846b489584-wvv5s    1/1     Running   0             7m50s
    3. Run the following command to check whether the files in the /data path of the new pod have been modified:
      kubectl exec web-demo-846b489584-d4d4j -- ls /data
      Expected output:
      static
      The static file is retained, indicating that the data in the file system can be stored persistently.
  5. Verify data sharing.
      Expected output:
      web-demo-846b489584-d4d4j   1/1     Running   0             7m
      web-demo-846b489584-wvv5s   1/1     Running   0             13m
    2. Run the following command to create a file named share in the /data path of either pod: In this example, select the pod named web-demo-846b489584-d4d4j.
      kubectl exec web-demo-846b489584-d4d4j --  touch /data/share
      Check the files in the /data path of the pod.
      Expected output:
      share
      static
    3. Check whether the share file exists in the /data path of another pod (web-demo-846b489584-wvv5s) as well to verify data sharing.
      Expected output:
      share
      static
      After you create a file in the /data path of a pod, if the file is also created in the /data path of the other pod, the two pods share the same volume.
Related Operations
You can also perform the operations listed in Table 3.
Table 3 Related operations
Operation
Updating an access key
Update the access key of object storage on the CCE console.
  1. Choose Storage in the navigation pane. In the right pane, click the PVCs tab. Click More in the Operation column of the target PVC and select Update Access Key.
  2. Upload a key file in .csv format. For details, see Obtaining an Access Key. Click OK.
    After a global access key is updated, all pods mounted with the object storage that uses this access key can be accessed only after being restarted.
Viewing events
View event names, event types, number of occurrences, Kubernetes events, first occurrence time, and last occurrence time of the PVC or PV.
  1. Choose Storage in the navigation pane. In the right pane, click the PVCs or PVs tab.
  2. Click View Events in the Operation column of the target PVC or PV to view events generated within one hour (events are retained for one hour).
Viewing a YAML file
View, copy, or download the YAML file of a PVC or PV.
  2. Click View YAML in the Operation column of the target PVC or PV to view or download the YAML.
