Halaman ini belum tersedia dalam bahasa lokal Anda. Kami berusaha keras untuk menambahkan lebih banyak versi bahasa. Terima kasih atas dukungan Anda.
Easily Switch Between Product Types
You can click the drop-down list box to switch between different product types.
Draining a Node
After you enable nodal drainage on the console, CCE configures the node to be non-schedulable and securely evicts all pods that comply with Rules for Draining Nodes on the node. Subsequent new pods will not be scheduled to this node.
When a node becomes faulty, nodal drainage quickly isolates the faulty node. The pods evicted from the faulty node will be scheduled by the workload controller to other nodes that are running properly.
NOTICE:
To ensure service availability during drainage, specify a disruption budget for your application. Otherwise, the application may become unavailable during pod rescheduling.
  • A cluster is available and the cluster version meets the following requirements:
    • v1.21: v1.21.10-r0 or later
    • v1.23: v1.23.8-r0 or later
    • v1.25: v1.25.3-r0 or later
    • Versions later than v1.25
  • To drain a node as an IAM user, you must have at least one of the following permissions (for details, see Namespace Permissions (Kubernetes RBAC-based)):
    • cluster-admin (administrator): read and write permissions on all resources in all namespaces.
    • drainage-editor: drain a node.
    • drainage-viewer: view the nodal drainage status but cannot drain a node.
When a node is drained, all pods on the node will be safely evicted. However, CCE will take specific actions for pods that meet certain filtering criteria.
Filter Criterion
Forced Drainage Enabled
Forced Drainage Disabled
The status.phase field of the pod is Succeeded or Failed.
Deletion
Deletion
The pod is not managed by the workload controller.
Deletion
Drainage cancellation
The pod is managed by DaemonSet.
None
A volume of the emptyDir type is mounted to the pod.
Eviction
The pod is a static pod directly managed by kubelet
None
None
The following operations may be performed on pods during node drainage:
  • Deletion: The pod is deleted from the current node and will not be scheduled to other nodes.
  • Eviction: The pod is deleted from the current node and rescheduled to another node.
  • None: The pod will not be evicted or deleted.
  • Drainage cancellation: If a pod on a node cancels drainage, the drainage process of the node is terminated and no pod is evicted or deleted.
  2. In the navigation pane, choose Nodes. On the displayed page, click the Nodes tab.
  3. Locate the target node and choose More > Nodal Drainage in the Operation column.
  4. In the Nodal Drainage window displayed, set parameters.
    • Timeout (s): The drainage task automatically fails after the preset timeout period. The value 0 indicates that the timeout period is not set.
    • Forced Drainage: If this function is enabled, pods managed by DaemonSet will be ignored, and pods with emptyDir volumes and pods not managed by controllers will be deleted. For details, see Rules for Draining Nodes.
  5. Click OK and wait until the node drainage is complete.
Kami menggunakan cookie untuk meningkatkan kualitas situs kami dan pengalaman Anda. Dengan melanjutkan penelusuran di situs kami berarti Anda menerima kebijakan cookie kami. Cari tahu selengkapnya
