Halaman ini belum tersedia dalam bahasa lokal Anda. Kami berusaha keras untuk menambahkan lebih banyak versi bahasa. Terima kasih atas dukungan Anda.
CCE Secrets Manager for DEW
Introduction
The dew-provider add-on is used to interconnect with Data Encryption Workshop (DEW), which allows you to mount secrets stored outside a cluster (DEW for storing sensitive information) to pods. In this way, sensitive information can be decoupled from the cluster environment, which prevents information leakage caused by program hardcoding or plaintext configuration.
Notes and Constraints
  • DEW includes Key Management Service (KMS), Cloud Secret Management Service (CSMS), and Key Pair Service (KPS). Currently, the dew-provider add-on can interconnect only with CSMS.
  • The CCE Secrets Manager for DEW add-on can be installed only on clusters v1.19 or later.
  • The CCE Secrets Manager for DEW add-on can be installed in CCE standard and CCE Turbo clusters.
  • A maximum of 500 SecretProviderClass objects can be created.
  • When the add-on is uninstalled, related CRD resources are deleted accordingly. Even if the add-on is reinstalled, the original SecretProviderClass object is unavailable. If you want to use the original SecretProviderClass resources after the add-on is uninstalled and then reinstalled, manually create them again.
How the Add-on Works
  • Basic mounting: After the dew-provider add-on is installed, you can create a SecretProviderClass object and declare and reference the volume in a pod. When the pod is started, the secret declared in the SecretProviderClass object is mounted to the pod.
  • Scheduled rotation: After a pod runs properly, if the secret declared in the SPC object and stored in CSMS is updated, the latest secret values can be updated to the pod through scheduled rotation. When using this capability, set the secret version to latest.
  • Real-time awareness of SPC changes: After a pod runs properly, if a user modifies the secret declared in the SPC object (for example, a secret is added or the version number is changed), the add-on can detect the change in real time and update the secret to the pod.
Installing the Add-on
  1. Log in to the CCE console and click the cluster name to access the cluster console. Click Add-ons in the navigation pane, locate CCE Secrets Manager for DEW on the right, and click Install.
  2. On the Install Add-on page, configure parameters in the Parameters area, as listed in the following table.
    rotation_poll_interval
    Rotation interval, in unit of m (instead of min).
    The rotation interval indicates the interval for sending a request to CSMS and obtaining the latest secret. The proper interval range is [1m, 1440m]. The default value is 2m.
  3. Click Install.
    After the add-on is installed, select the cluster and click Add-ons in the navigation pane. On the displayed page, view the add-on in the Add-ons Installed area.
Components
Table 1 Add-on components
Component
Resource Type
dew-provider
A component that obtains specified secrets from CSMS and mounts them to the pods
DaemonSet
secrets-store-csi-driver
A component that maintains two CRDs, SecretProviderClass (SPC) and SecretProviderClassPodStatus (spcPodStatus). SPC is used to describe the secret that users are interested in (such as the secret version and name). It is created by users and will be referenced in pods. spcPodStatus is used to trace the binding relationships between pods and secrets. It is automatically created by csi-driver and requires no manual operation. One pod corresponds to one spcPodStatus. After a pod is started, a spcPodStatus is generated for the pod. When the pod lifecycle ends, the spcPodStatus is deleted accordingly.
DaemonSet
Mounting a Credential Using a Volume
  1. Create a ServiceAccount.
    1. Create a ServiceAccount object, which declares the secret names that can be used by services. If a user references a secret that is not declared here, the mounting will fail. As a result, the pod cannot run.
      Create the serviceaccount.yaml file based on the template below, and declare the secret names that can be used by services in the cce.io/dew-resource field. Here, secret_1 and secret_2 are declared, indicating that the service is allowed to reference two secrets. In subsequent operations, if the user references secret_3 in the service, the verification fails. As a result, the secret cannot be mounted and the pod cannot run.
      apiVersion: v1
      kind: ServiceAccount
        annotations:
          cce.io/dew-resource: "[\"secret_1\",\"secret_2\"]"  #secrets that allow pod to use
      Ensure that the secrets declared here exist in CSCM. Otherwise, even if the verification is successful, an error occurs when the corresponding secret is obtained from CSCM. As a result, the pod cannot run properly.
    2. Run the following command to create the ServiceAccount:
      kubectl apply -f serviceaccount.yaml
    3. Check whether the ServiceAccount object is successfully created.
      $ kubectl get sa
      NAME       SECRETS   AGE
      default         1         18d   # This is the default ServiceAccount object of the system.
      nginx-spc-sa    1         19s   # This is the newly created ServiceAccount object.
      A ServiceAccount object named nginx-spc-sa has been created. This object will be referenced in pods.
  2. Create a SecretProviderClass.
    1. The SecretProviderClass object is used to describe the secret information (such as the version and name) that users are interested in. It is created by users and will be referenced in pods.
      Create the secretproviderclass.yaml file using the template below. Pay attention to the objects field in parameters, which is an array used to declare the secret to be mounted.
      apiVersion: secrets-store.csi.x-k8s.io/v1
      kind: SecretProviderClass
        provider: cce     # The value is fixed at cce.
        parameters:
          objects: |
                - objectName: "secret_1"
                  objectVersion: "v1"
                  objectType: "csms"
      Type
      Mandatory
      objectName
      String
      Yes
      Credential name. Set this parameter to the secret referenced in ServiceAccount. If there are multiple object names defined in the same SecretProviderClass, each value of the objectName parameter must be unique. Otherwise, the mounting fails.
      objectAlias
      String
      No
      File name of the secret written into the container. If this parameter is not specified, the file name of the secret written into the container is the value of objectName by default. If this parameter is specified, the value must be different from objectName and from the objectAlias and objectName values of other secrets. Otherwise, the mounting fails.
      objectType
      String
      Yes
      Secret type. Only csms is supported. A value other than csms is invalid.
      objectVersion
      String
      Yes
      Secret version
      • Specify a version, for example, v1 or v2.
      • Use the latest version, for example, latest. When objectVersion is set to latest, if the corresponding secret in CSCM is updated, the secret will be updated to the pod after a certain interval (rotation_poll_interval).
    2. Run the following command to create a SecretProviderClass object:
      kubectl apply -f secretproviderclass.yaml
    3. Check whether the SecretProviderClass object has been created.
      $ kubectl get spc
      NAME   AGE
      spc-test   20h
      A SecretProviderClass object named spc-test is created. This object will be referenced in pods subsequently.
  3. Create a pod.
    The following describes how to create an Nginx application.
    1. Define a workload, reference the created ServiceAccount object in serviceAccountName, and reference the created SPC object in secretProviderClass, specify the mount path of the container in mountPath. (Do not specify special directories such as / and /var/run. Otherwise, the container may fail to be started.)
      apiVersion: apps/v1
      kind: Deployment
        labels:
          app: nginx
        replicas: 1
        selector:
          matchLabels:
            app: nginx
        template:
            labels:
              app: nginx
            serviceAccountName: nginx-spc-sa   # Reference the created ServiceAccount.
            volumes:
              - name: secrets-store-inline
                csi:
                  driver: secrets-store.csi.k8s.io
                  readOnly: true
                  volumeAttributes:
                    secretProviderClass: "spc-test"  # Reference the created SPC.
            containers:
              - name: nginx-spc
                image: nginx:alpine
                imagePullPolicy: IfNotPresent
                volumeMounts:
                    mountPath: "/mnt/secrets-store"  # Define the mount path of secrets in the container.
                    readOnly: true
            imagePullSecrets:
              - name: default-secret
    2. Create a pod.
      kubectl apply -f deployment.yaml
    3. Check whether the pod has been created.
      $ kubectl get pod
      NAME                     READY   STATUS   RESTARTS   AGE
      nginx-spc-67c9d5b594-642np     1/1     Running    0            20s
    4. Access the container and check whether the specified secret is written properly. For example:
      $ kubectl exec -ti nginx-spc-67c9d5b594-642np -- /bin/bash
      root@nginx-spc-67c9d5b594-642np:/#
      root@nginx-spc-67c9d5b594-642np:/# cd /mnt/secrets-store/
      root@nginx-spc-67c9d5b594-642np:/mnt/secrets-store#
      root@nginx-spc-67c9d5b594-642np:/mnt/secrets-store# ls
      secret_1
      The command output shows that secret_1 declared in the SPC object has been written to the pod.
      In addition, you can obtain spcPodStatus to check the binding relationship between pods and secrets. For example:
      $ kubectl get spcps
      NAME        AGE
      nginx-spc-67c9d5b594-642np-default-spc-test   103s
      $ kubectl get spcps nginx-spc-67c9d5b594-642np-default-spc-test -o yaml
      status:
      mounted: true
      objects:    # Mounted secret
      - id: secret_1
      version: v1
      podName: nginx-spc-67c9d5b594-642np   # Pod that references the SPC object
      secretProviderClassName: spc-test               # SPC object
      targetPath: /mnt/paas/kubernetes/kubelet/pods/6dd29596-5b78-44fb-9d4c-a5027c420617/volumes/kubernetes.io~csi/secrets-store-inline/mount
Mounting a Credential Using a Secret
CCE Secrets Manager for DEW must be 1.1.1 or later.
      apiVersion: v1
        annotations:
      $ kubectl get sa
      NAME       SECRETS   AGE
    1. Create the secretproviderclass.yaml file using the template below.
        provider: cce
        parameters:
          # Reference a secret in CSMS.
          objects: |
              objectType: "csms"
              objectVersion: "latest"
              jmesPath:
                - path: username
                  objectAlias: dbusername
                - path: password
                  objectAlias: dbpassword
        # Create a CCE secret based on the CSMS secret and mount the secret to a pod.
        secretObjects:
          - secretName: my-secret-01
            type: Opaque
            data:
              - objectName: dbusername
                key: db_username_01
              - objectName: dbpassword
                key: db_password_01
      Table 2 objects parameter
      Type
      Mandatory
      objectName
      String
      Yes
      objectType
      String
      Yes
      objectVersion
      String
      Yes
      Secret version.
      jmesPath
      Array of Object
      Yes
      jmesPath is used to extract key-value pairs from objects in JSON format. CCE Secrets Manager for DEW uses this tool to support Secret mounting.
      • path: Enter the key in a DEW secret. The key cannot contain special characters such as +, -, {}, and ().
      • objectAlias: name of the file mounted to a pod. The value must be the same as the value of objectName defined in secretObjects.
      Table 3 secretObjects parameter
      Type
      Mandatory
      secretName
      String
      Yes
      Secret name
      type
      String
      Yes
      Secret type
      data
      Array of Object
      Yes
      • objectName: name of the file mounted to the pod. The value must be the same as the value of objectAlias specified in objects.
      • key: key in a secret. The value can be used to reference the encrypted content in a pod.
      $ kubectl get spc
      NAME   AGE
      nginx-deployment-spc-k8s-secrets   20h
  3. Create a pod. The following describes how to create an Nginx application.
    apiVersion: apps/v1
    kind: Deployment
      labels:
        app: nginx-k8s-secrets
      replicas: 1
      selector:
        matchLabels:
      template:
          labels:
          containers:
          - name: nginx-deployment-k8s-secrets
            image: nginx
            volumeMounts:   # Mount the secret to a container.
              - name: secrets-store-inline   # Name of the volume to be mounted
                mountPath: "/mnt/secrets"    # Path of the container to be mounted
                readOnly: true
            env:    # Reference the secret in environment variables.
              - name: DB_USERNAME_01      # Environment variable name in the workload
                valueFrom:
                  secretKeyRef:
                    name: my-secret-01    # Secret name specified in the SPC
                    key: db_username_01   # The value of the key specified in the SPC
              - name: DB_PASSWORD_01
                valueFrom:
                  secretKeyRef:
                    key: db_password_01
          imagePullSecrets:
          volumes:    # Use the secret specified in the SPC to create a volume.
            - name: secrets-store-inline  # Custom volume name
              csi:
                readOnly: true
                volumeAttributes:
                  secretProviderClass: nginx-deployment-spc-k8s-secrets   # Name of the SPC created in the previous step
  4. Verify the result.
    $ kubectl get secrets
    NAME             TYPE                             DATA   AGE
    default-secret   kubernetes.io/dockerconfigjson   1      33d
    my-secret-01     Opaque                           2      1h
    The output shows that a secret named my-secret-01 has been created using secret_1 specified in the SPC object.
Scheduled Rotation
As described before, you can use this add-on to complete the mount secrets, that is, you can write the secrets stored in CSMS to a pod.
To change the secret version declared in the SPC object to latest, run the following command:
  provider: cce
  parameters:
    objects: |
            objectVersion: "latest"  # change "v1"to "latest"
            objectType: "csms"
After the SPC object is updated, the add-on periodically sends a request to CSMS to obtain the value of secret_1 of the latest version and updates the value to the pod that references the SPC object. The interval for the add-on to periodically send requests is specified by rotation_poll_interval set in Installing the Add-on.
Real-Time Detection of SPC Changes
SPC changes are already detected in real time in Mounting a Credential Using a Volume and Scheduled Rotation. For demonstration, add secret secret_2 to the SPC object as follows:
  provider: cce
  parameters:
    objects: |
            objectType: "csms"
          - objectName: "secret_2"
            objectVersion: "v1"
            objectType: "csms"
After the SPC object is updated, the new secret_2 is quickly mounted to the pod that references the SPC object.
Viewing Component Logs
View the pod where the add-on runs.
$ kubectl get pod -n kube-system
csi-secrets-store-76tj2       3/3     Running     0           11h
dew-provider-hm5fq            1/1     Running     0           11h
View pod logs of the dew-provider component.
$ kubectl logs dew-provider-hm5fq -n kube-system
...Log information omitted...
View the pod logs of the csi-secrets-store component. As the pod of the csi-secrets-store component contains multiple containers, you must run the -c command to specify a container when viewing pod logs. The secrets-store container is the major service container of the add-on and contains the majority of the logs.
$ kubectl logs csi-secrets-store-76tj2 -c secrets-store -n kube-system
Kami menggunakan cookie untuk meningkatkan kualitas situs kami dan pengalaman Anda. Dengan melanjutkan penelusuran di situs kami berarti Anda menerima kebijakan cookie kami. Cari tahu selengkapnya
