Help Center/ Cloud Container Engine/ User Guide (ME-Abu Dhabi Region)/ Network/ Container Network/ Cloud Native Network 2.0 Settings/ Binding a Subnet and Security Group to a Namespace or Workload Using a Container Network Configuration
In a CCE Turbo cluster, you can configure subnets and security groups for containers by namespace or workload using NetworkAttachmentDefinition CRDs. If you want to configure a specified container subnet and security group for a specified namespace or workload, create a container network configuration and associate it with the target namespace or workload. In this way, service subnets can be planned or services can be securely isolated.
The following table lists the resources that a container network configuration can be associated with.
Table 1 Associated resources
Category
Resources a Container Network Configuration Can Associate with
Namespace
Workload
Subnet and security group configurations
All workloads created in the namespace associated with a container network configuration use the same subnet and security group configurations.
The workloads associated with the same container network configuration use the same subnet and security group configurations.
Supported cluster versions
Available only in CCE Turbo clusters of 1.23.8-r0, 1.25.3-r0, or later.
Available only in CCE Turbo clusters of 1.23.11-r0, 1.25.6-r0, 1.27.3-r0, 1.28.1-r0, or later.
Notes and Constraints
A namespace can be associated with only one container network configuration.
Only the custom container network configurations that are not associated with any namespace can be specified.
  • The priorities (in descending order) of the container network configurations used by a pod are as follows: Container network configuration directly associated with the pod > Container network configuration associated with the pod namespace > Default container network configuration of the cluster (default-network)
  • If default-network is available in a cluster, it takes effect on all pods where no custom container network configuration has been configured. The default container subnet in the network settings on the Overview page is the container subnet in default-network. default-network cannot be deleted.
  • Only the default container network configuration supports dynamic pre-binding of container NICs. When the quota of node NICs is used up, the pod that uses the custom container network configuration attempts to unbind the pre-bound NIC of the default container network configuration, leading to slower pod startup. Therefore, if you need to frequently use the custom container network configuration, disable dynamic pre-binding of global container NICs in the target cluster. If you require high-speed pod elasticity using the default container network configuration, properly plan dynamic pre-binding of container NICs in the target node pool based on scheduling.
  • If a workload with a fixed IP address needs to be associated with a new container network configuration, the fixed IP address will be invalid when pods are rebuilt. In this case, delete the workload, release the fixed IP address, and create a workload again.
  • Before deleting a custom container network configuration, delete the pods (with the cni.yangtse.io/network-status annotation) created using the configuration in the target namespace. For details, see Deleting a Container Network Configuration.
Using the CCE Console to Create a Container Network Configuration of the Namespace Type
  1. Log in to the CCE console.
  2. Click the cluster name to access the cluster console. Choose Settings in the navigation pane. In the right pane, click the Network tab.
  3. View the Container Network Security Policy Configuration (Namespace Level) and click Add. In the window that is displayed, configure parameters such as the pod subnet and security group.
    • Name: Enter a name that contains a maximum of 253 characters. Do not use default-network, default, mgnt0, or mgnt1.
    • Associated Resource Type: resource type associated with the custom container network configuration. For details, see Table 1. To create a container network configuration of the namespace type, select Namespace.
    • Namespace: Select the namespace to be associated. The namespaces associated with different container network configurations must be unique. If no namespace is available, click Create Namespace to create one.
    • Pod Subnet: Select a subnet. If no subnet is available, click Create Subnet to create one. After the subnet is created, click the refresh button. A maximum of 20 subnets can be selected.
    • Associate Security Group: The default value is the container ENI security group. You can also click Create Security Group to create one. After the security group is created, click the refresh button. A maximum of five security groups can be selected.
  4. Click OK. After the creation, you will be redirected to the custom container network configuration list, where the new container network configuration is included.
Using the CCE Console to Create a Container Network Configuration of the Workload Type
    • Associated Resource Type: resource type associated with the custom container network configuration. For details, see Table 1. To create a container network configuration of the workload type, select Workload.
  5. When creating a workload, you can select a custom container network configuration.
    1. In the navigation pane, choose Workloads. In the right pane, click the Deployments tab.
    2. Click Create Workload in the upper right corner of the page. In the Advanced Settings area, choose Network Configuration and determine whether to enable a specified container network configuration.
    3. Select an existing container network configuration. If no configuration is available, click Add to create one.
    4. After the configuration, click Create Workload.
      Return to the Settings page. In the container network configuration list, the name of the resource associated with the created container network configuration is displayed.
Using Kubectl to Create a Container Network Configuration of the Namespace Type
This section describes how to use kubectl to create a container network configuration of the namespace type.
  1. Use kubectl to access the cluster. For details, see Connecting to a Cluster Using kubectl.
  2. Modify the networkattachment-test.yaml file.
    vi networkattachment-test.yaml
    apiVersion: k8s.cni.cncf.io/v1
    kind: NetworkAttachmentDefinition
      annotations:
        yangtse.io/project-id: 05e38**
      namespace: kube-system
      config: |
        "type":"eni-neutron",
        "args":{
          "securityGroups":"41891**",
          "subnets":[
              "subnetID":"27d95**"
        "selector":{
          "namespaceSelector":{
            "matchLabels":{
              "kubernetes.io/metadata.name":"default"
    Table 2 Key parameters
    Mandatory
    Type
    apiVersion
    Yes
    String
    API version. The value is fixed at k8s.cni.cncf.io/v1.
    kind
    Yes
    String
    Type of the object to be created. The value is fixed at NetworkAttachmentDefinition.
    Yes
    String
    Project ID.
    name
    Yes
    String
    Configuration item name.
    namespace
    Yes
    String
    Namespace of the configuration resource. The value is fixed to kube-system.
    config
    Yes
    Table 3 object
    Configuration content, which is a string in JSON format.
    Table 3 config parameters
    Mandatory
    Type
    type
    Yes
    String
    The value is fixed at eni-neutron.
    args
    No
    Table 4
    object
    Configuration parameters.
    selector
    No
    Table 5 object
    Namespace on which the configuration takes effect.
    Table 4 args parameters
    Mandatory
    Type
    securityGroups
    No
    String
    Security group ID. If no security group is planned, ensure that the security group is the same as that in default-network.
    How to obtain:
    Log in to the VPC console. In the navigation pane, choose Access Control > Security Groups. Click the target security group name and copy the ID on the Summary tab page.
    subnets
    Yes
    Array of subnetID Objects
    List of container subnet IDs. At least one subnet ID must be entered. The format is as follows:
    [{"subnetID":"27d95**"},{"subnetID":"827bb**"},{"subnetID":"bdd6b**"}]
    Subnet ID not used by the cluster in the same VPC.
    How to obtain:
    Log in to the VPC console. In the navigation pane, choose Virtual Private Cloud > Subnets. Click the target subnet name and copy the Subnet ID on the Summary tab page.
    Table 5 selector parameters
    Mandatory
    Type
    namespaceSelector
    No
    matchLabels Object
    A Kubernetes standard selector. Enter the namespace label in the following format:
    "matchLabels":{
    The namespaces of different configurations cannot overlap.
  3. Create a NetworkAttachmentDefinition.
    kubectl create -f networkattachment-test.yaml
    If information similar to the following is displayed, the NetworkAttachmentDefinition has been created.
    networkattachmentdefinition.k8s.cni.cncf.io/example created
Using Kubectl to Create a Container Network Configuration of the Workload Type
This section describes how to use kubectl to create a container network configuration of the workload type.
      annotations:
        yangtse.io/project-id: 80d5a**
      config: |
        "args":{
          "securityGroups":"f4983**",
          "subnets":[
              "subnetID":"5594b**"
    Table 6 Key parameters
    Mandatory
    Type
    apiVersion
    Yes
    String
    kind
    Yes
    String
    Yes
    String
    Project ID.
    name
    Yes
    String
    namespace
    Yes
    String
    config
    Yes
    Table 3 object
    Table 7 config parameters
    Mandatory
    Type
    type
    Yes
    String
    args
    No
    Table 4
    object
    Table 8 args parameters
    Mandatory
    Type
    securityGroups
    No
    String
    How to obtain:
    subnets
    Yes
    How to obtain:
  4. Create a Deployment workload and associate it with the newly created container network configuration.
    apiVersion: apps/v1
    kind: Deployment
      replicas: 3
      selector:
        matchLabels:
          app: nginx
      template:
          labels:
            app: nginx
            yangtse.io/network: "example"  # Name of the custom container network configuration, which can be used to obtain all pods associated with the container network configuration by label
          annotations:
          containers:
            - name: container-0
              image: nginx:alpine
              resources:
                limits:
                  cpu: 100m
                  memory: 200Mi
                requests:
                  cpu: 100m
                  memory: 200Mi
          imagePullSecrets:
            - name: default-secret
    • yangtse.io/network: name of the specified custom container network configuration. Only a container network configuration that is not associated with any namespace can be specified. Add this parameter to the label so that you can use the label to obtain all pods associated with this container network configuration.
You can delete the new container network configuration or view its YAML file.
Before deleting a container network configuration, delete all pods using the configuration. Otherwise, the deletion will fail.
  1. Run the following command to filter the pods that uses the configuration in the cluster (example is used as an example):
    kubectl get pod -A -o=jsonpath="{.items[?(@.metadata.annotations.cni\.yangtse\.io/network-status=='[{\"name\":\"example\"}]')]['metadata.namespace', 'metadata.name']}"
    The command output contains the pod name and namespace associated with the configuration.
  2. Delete the owner of the pod. The owner may be a Deployment, StatefulSet, DaemonSet, or Job.
