Logging In to a Container
If you encounter unexpected problems when using a container, you can log in to the container to debug it.
Using kubectl
  1. Use kubectl to access the cluster. For details, see Connecting to a Cluster Using kubectl.
  2. Run the following command to view the created pod:
    kubectl get pod
    The example output is as follows:
    NAME                               READY   STATUS    RESTARTS       AGE
    nginx-59d89cb66f-mhljr             1/1     Running   0              11m
  3. Query the container name in the pod.
    kubectl get po nginx-59d89cb66f-mhljr -o jsonpath='{range .spec.containers[*]}{.name}{end}{"\n"}'
    container-1
  4. Run the following command to log in to the container-1 container in the nginx-59d89cb66f-mhljr pod:
    kubectl exec -it nginx-59d89cb66f-mhljr -c container-1 -- /bin/sh
  5. To exit the container, run the exit command.
