x-apigateway-backend.functionEndpoints
Meaning: Function backend service definition.
Scope of effect: x-apigateway-backend
Example:
paths:
'/users/{userId}':
get:
produces:
- "application/json"
parameters:
- name: "X-Auth-Token"
description: "Authentication token"
type: "string"
in: "header"
required: true
responses:
default:
description: "default response"
x-apigateway-request-type: "public"
x-apigateway-backend:
type: "FUNCTION"
functionEndpoints:
version: "v1"
function-urn: ""
invocation-type: "synchronous"
timeout: 30000
Parameter |
Mandatory |
Type |
Description |
function-urn |
Yes |
String |
Function URN. |
version |
Yes |
String |
Function version. |
invocation-type |
Yes |
String |
Function invocation type. The value can be async or sync. |
timeout |
No |
Number |
Function timeout in milliseconds. The range is 1–60,000, and the default value is 5000. |
